On a new build I take the bike out and get in 3rd gear, then go from 30mph up to 60mph full throttle and letting off until its back down to 30mph and repeat. I do this ten times over. If its just a new bike off the showroom floor, then I just take it easy for the first 50 miles in varying speeds without remaining a constant speed. Then I ride it as normal.
^^^Yep^^^
MotoTune's procedure all the way...did the 2017 Dyna on ride home from dealer...30/60/30 x10 in 3rd.
When I redid the top end on my evo I did the heat cycle thing per my machinist's instructions. New KB pistons and Hastings rings. Since he has been racing a basically hand built '39 Indian LSR bike for years (among many other things) I followed his advice to the letter. It had 10k on the top end and was running very well when I traded it in on the RK.
I would say go with the instructions that come with the ring set you are using.
