I typically run about 22-2400 rpm..........at 3,000 rpm, my engine is screaming "shift me". With that reasoning, I'd have to be running near 90 mph before I could shift into 6th.
It is counterintuitive to me that a greater engine speed creates less wear especially when the engine just sounds right and is very responsive at that rpm. Thoughts?
Think about riding a bicycle. Would you be more comfortable straining to peddle in a higher gear, or more comfortable turning your legs slightly faster in a lower gear?
If you can't increase speed/RPM's smoothly and quickly when rolling on the throttle; then you're lugging the motor. Roll on the throttle, if it chugs/bucks, you need to be at higher RPM/lower gear. Cruising through downtown at 5000 RPM will wear out your motor, just like lugging will. Find the sweet spot.
I have been also told by the big aftermarket manufacturers don't lug your bike. stay above 3k I have always shifted around 3.5 to 4k now I have a built motor so 4k it is..
I've shifted mine at 2K, 2500, 3K, 4K and never seen a single spec of fuel mileage change in any of them. Logic and my mechanical background tells me that the fewer times a metal part goes past another metal part, the less it's gonna wear. I don't mind cruising at 2K if I'm on flat ground with no real load, 80mph is 3K on the dot with my tire size. If I'm trying to merge etc, I'll run it up a little higher but otherwise I shift between 2500-3000 and the RPM and the revs fall back to about 2K. As long as you don't try to pin the throttle when the revs are down I don't think you're going to harm a thing. Easy throttle pressure and let the engine do it's job. It's easier on everything, including the clutch.
After all these years on a Harley I've been doing it wrong, riding around at 2800-3000 at highway speeds around town at 2200-2400 in the lower gears. The older TC's with single phase alternator don't crank out 14+ volts till about 2200 rpm. On a flat/level road, think Indiana and parts of Ohio 6th gear at 65 mph was pretty happy on the Roadie, need to pass downshift, go a hill downshift. It's that simple.
