How to increase lean angle?
Old Jun 26, 2007 | 10:20 PM
redsled's Avatar
redsled
Default RE: How to increase lean angle?
Technique-wise one of the biggest mistakes people make is not getting on the gas early enough in a corner, resulting in loading up the front end, reducing corner clearance, and scraping more than necessary. Being on the gas at the apex, and not on the brakes, will give you a little more clearance. (As will hanging off, or even just bending your body into the turn at the waist - no hanging off per se).
After that, on a Fatty, I don't know of much else, by way of suspension or wheels, unless you do something radical. I guess you could add longer forks, but again, on a Fatty that might look kinda odd.
FWIW, the cornering lean angles for all the bikes are published in most of the specs I've seen (haven't looked lately). Used to be there often a degree or two difference from left to right - kickstand or pipes was usually the culprit.
Old Jun 26, 2007 | 10:32 PM
YUCK's Avatar
YUCK
I like putting metal to the pavement,,,,enjoy the light show at nite,,,,scrape it till it falls off....thats Y floorboards fold....
Old Jun 26, 2007 | 10:43 PM
electaRICK's Avatar
electaRICK
I've rubbed the crome off my derby cover
Old Jun 26, 2007 | 10:51 PM
YUCK's Avatar
YUCK
using your tongue,,,don't count,,,damm thats getting down....
ORIGINAL: electaRICK
Old Jun 26, 2007 | 11:45 PM
michaelbarry's Avatar
michaelbarry
ORIGINAL: spike95
Tryhanging your body off the side like the sport bike guys do. I had a hell of a time after I put on my Thunderheader. It'll scrape before the board even touches. I personally don't like that feeling at all, especially when I'm hauling a@$. I lean forward a little and hang my butt off the seatas much as possible, and I rarely ever touch the ground any more.
My LongShots do the same thing..They're dragged flat on one part of the bottom one now.
Old Jun 26, 2007 | 11:59 PM
Tripper's Avatar
Tripper
Use a grinder wheel to remove excess metal from your floor boards or just let the sparks fly until they wear down enough to clear the pavement.
Old Jun 27, 2007 | 01:27 AM
Boxjoint's Avatar
Boxjoint
I'm feelin' ya Anibuss. I am also an ex-sportbike guy.
Me-I plan on getting a Buell within 4 years. I like the superglide but I do miss tossing around a sport bike. The danger is with the peg scraping is that if you are already scraping you have very very little room for corrections mid corner before hard parts start digging.
Old Jun 27, 2007 | 09:11 AM
1flhtk4me's Avatar
1flhtk4me
Buy a Road Glide!
Old Mar 23, 2010 | 01:02 PM
Klotz's Avatar
Klotz
You could always switch from floorboards to pegs, they're a lot cheaper to keep replacing.
Old Mar 23, 2010 | 01:37 PM
oct1949's Avatar
oct1949
I'd think that those who lower there bikes should expect the floorboard to touch easier.
Most riders that get aggressive in turns have them scrap anyway even at stock height.
As far as something to help from grinding the floorboard off I'd think one could make something like a small piece of metal that would go under the floorboard and contact the road before the floorboard itself hit the road and would keep it from grinding off the edge of the Fl Board.
Here in the flat lands of Ind. we don't have many twisties.
In 25k I think mine have hit once, so scraping is not an issue. But I an older dude and the bike is stock height and don't ride very hard either.
