Tire Cupping Cause?
Old Jul 12, 2018 | 08:06 AM
PDB17UltraRG's Avatar
PDB17UltraRG
Air pressures do it all check your pressures prior to every ride and you’ll get longer tire life a better wear
Old Jul 12, 2018 | 03:35 PM
SDozier's Avatar
SDozier
Checked front tire air pressure this morning: 36 psi Rear: 38 psi This seems within range. I will change the fork oil and have the steering bearing checked / adjusted next week.
SUP
Old Jul 12, 2018 | 05:30 PM
moparnut72's Avatar
moparnut72
Originally Posted by Ridewva
This is the reason. Some tread designs are more prone than others but I've never had a motorcycle front tire that did not cup because the front tire wears from resistance torque either braking or just rolling resistance. The rear wears more evenly because acceleration offsets braking and engine braking.
I agree with this statement. I was told the same thing many years ago and it makes perfect sense. Back in the 70's I used Dunlop K70 tires. They have a blocky tread and were prone to cupping. I don't know if was or is an approved method but I would dismount the tire when cupping became quite pronounced and turn it around so that it rolled in the opposite direction. It usually got me some more mileage. Tires were a lot narrower than they are today so it wasn't that bad a job.
kk
Old Jul 13, 2018 | 12:22 AM
banddirector's Avatar
banddirector
I keep 38 psi in the front tire, and 40 in the rear, and no cupping problem. When I used to keep tires in the low 30s they cupped like crazy ...
Old Jul 13, 2018 | 01:07 AM
1Canuck's Avatar
1Canuck
38 front & 42 rear. Have done that since the last tire cupped with 36/40.
changed front at 42K km with a hint of cupping and rear at 27k km again with a hint of cupping.
low pressure causes cupping in conjunction with overall weight. The spec 36/40 is not for all weight classes.
Old Jul 13, 2018 | 06:55 AM
BigDawgQC's Avatar
BigDawgQC
I can't figure it out. I've had three different Tourers, '09 Road King, '14 Street Glide & now '15 Ultra Limited. I'm **** about pressures. Never had an issue with front tires at all. But throughout ownership, I've had some OEM rear tires cup & some not. Currently, the '15 Ultra, with 6700 miles on it, (I bought a garage queen with 2700 miles on it two months ago) the tire looks good, good tread depth & yet, makes that "roar" sound in the turns like a cup tire can make. And it's not the bearings. Go figure.
Old Jul 13, 2018 | 07:15 AM
ClifWideGlide's Avatar
ClifWideGlide
The last time I changed tires about a year ago I was tired of the Dunlop’s that HD recommended and I went with Pirelli Night Dragon’s and it was suggested to me on this forum to contact Pirelli about their recommendation for tire pressure. I did and they were way higher than what HD recommended so I set them at what Pirelli suggested and haven’t had any wear issues yet. Every set of Dunlop’s I ever had would always show cupping within 3-5,000 miles. And before I had always used the HD spec for tire pressures so it may not have been a Dunlop problem.
Old Jul 13, 2018 | 06:54 PM
Ridewva's Avatar
Ridewva
After replacing tires typically after a couple thousand miles I can hear howling from the front tire when cornering either direction, not when going straight though. It's from cupping and it gradually becomes louder as the tires wear. My RK front tire has almost 12K, is cupped, therefore howls pretty loud when over on a slight lean...doesn't hurt a thing. It's about time I replace both tires actually I'm just tickled they made it that many miles.
NCTim
Jun 2, 2023 09:48 AM
dope_man_21
Oct 6, 2021 05:34 PM
Mugsy666
Sep 27, 2014 01:30 AM
frozensoul
Nov 15, 2010 02:34 PM
missile
Apr 13, 2010 10:01 PM
