Reliability/longevity of EVO vs. early Twin Cam
Old Sep 22, 2018 | 08:02 AM
Tarkus60's Avatar
Tarkus60
I would get on my 02 and go anywhere and not worry one bit!
Old Sep 22, 2018 | 08:33 AM
F150HD's Avatar
F150HD
good thread.
Old Sep 22, 2018 | 08:37 AM
Campy Roadie's Avatar
Campy Roadie
I guess that's the difference between a Marine and Soldier
Semper Fi Brother
Old Sep 22, 2018 | 10:12 AM
sharkey's Avatar
sharkey
I live near a school that trains HD mechanics. Long ago I wanted to hop up and tour on an FXR, but instructors there convinced me to go with a then new FXDXT. Their advise was correct. I went bigger bore/stroke, got heads done, put gear drive cams in and rode that bike thru many states and provinces. 111hp/117ft lbs. An EVO wouldn’t have been as reliable at the horsepower level I wanted.
Also; nowadays, unless you’re a totally self sufficient mechanic, students aren’t even taught on EVO’s.
Ancient, romaticized platform...as the twin cam will be in a few years.
Old Sep 22, 2018 | 11:16 AM
mitchxout's Avatar
mitchxout
I disagree and so do the HD engineers. Why do you think they went back to single cam? Btw, S&S motors are also single cam.
Old Sep 22, 2018 | 11:40 AM
Kingglide549's Avatar
Kingglide549
The TC would have been ok if they had not used a flexible flywheel arrangement and under engineered cam geometry
Old Sep 22, 2018 | 11:51 AM
Greezey Rider's Avatar
Greezey Rider
There are a few reasons that they went back to a single cam...None of them have to do with the EVO.
Because so many Harley riders are too stupid to maintain the cam tensioners on a T/C.
The valve train geometry is way better on a T/C than on an EVO, Shovel or what have you.
The idea behind the T/C was to correct the angle of the pushrods in relation to the rockers (kind'a like the Sportsters have always been) and it worked very well.
Sadly the government stepped in and told them that they couldn't be gear driven because of noise level rules, so they did chain driven, which is quieter but requires some attention from time to time.
Because they're based on the EVO platform.
As I have said many times before, to my customers at the shop and on these forums, The EVO was a great platform and was one of the things that saved Harley from going out of business, But they are not the best motor Harley ever built.
Pop a set of gear driven cams in a (pre-2003) T/C and weld the flywheels and you have the best, most reliable motor Harley has ever built.
Old Sep 22, 2018 | 12:01 PM
ShadowforNow's Avatar
ShadowforNow
Originally Posted by CndUltra95
There where even porous cases during the mid to early nineties .
Oil would seep through the cases and was found with a die and ultra violet light to locate the seepage.
All being equal they are reliable machines that if treated like a machine and not beaten they can and do run for many miles with basic repairs.
Rob
Seep through the steel itself rather than a gasket?
Originally Posted by badcooky
The TC is a POS the MOCO is hoping to forget.
Go to your local HD on Monday morning, have a look in there'll be mostly the TC POS in there being worked on because they have exploded the timing chest or scissored the crank or any of the over 30 recalls for the bucket of schit.
The Evo is a classic and has style and charisma the TC is just a POS.
I'd guess part of the reason most bikes in the shop are TC is due to there being more of them out there than EVOs.
Originally Posted by Kingglide549
The TC depending on the year with its mechanical problems for birth defects, it also has computers that will shut it dwn.
This is something I was looking for. Things about the early TC models other than mechanical and how it compares to EVO bikes. Do the early TC have more electronics on it's carbureted models compared to EVO bikes?
Originally Posted by Newharleylover
What I did notice is that out of all the bikes I've owned up to that point the Road King ran the hottest. Hot starts weren't pleasant at all!
The bike I have now is a different animal in my opinion. It runs cooler, it rides smoother, it's simpler to work on. I put 3500 miles on it since the end of May and the engine oil level hasn't dropped. I miss the 6 speed of the RKC however the sound of 3000-3200 rpm on the highway is music to my ears. OK it's 30 years old and some things need attention, none of which right now would produce a catastrophe. When riding season is over I'm going to tear into it and fix or replace the bothersome things and by spring it will be in the condition where I could ride anywhere any time for as long as I want.
Something I don't know is whether the TC runs hotter due to it actually running hotter or if the TC does a better job of dissipating heat, which then gives the impression of it running hotter.
The purpose of the two cams in the TC bikes was for the sake of the motor co doing something different and having more to patent, if I'm not mistaken.
I read somewhere the S&S motors are available in single and twin cam editions and the power output is the same for both.
Its odd the government can step in and tell a manufacturer like HD they have to use chain driven rather than gear driven cams due to noise rules. I wonder how much of a difference the noise can be. Maybe HD just said the gov told them to use chain without it being true. Or perhaps overstating things, saying they can't meet the noise level rules with gear driven cams where they could if they really wanted to.
Geezey: Thanks for the great post.
Anyone know how much this would cost for gear driven cams and welding the flywheels, parts and labor?
Old Sep 22, 2018 | 12:28 PM
Super Glidester's Avatar
Super Glidester
Originally Posted by Nomadmax
How about from Ohio to the Arctic Circle, twice on a Twin Cam? Bravery is in the eye of the beholder.
Yup, thats what the bikes look like in Alaska, spare fuel can, mud and all...I have no complaints about my Twinkie...
Old Sep 22, 2018 | 12:29 PM
Greezey Rider
The EPA makes these arbitrary rules.
