Question about heated gear
Old Oct 6, 2018 | 05:22 PM
matthew6279's Avatar
matthew6279
Default Question about heated gear
Does anyone know if the Gerbing heated socks work with Venture heated pants liner? The connections are the same. Would there be any other reason they wouldn't work??
Old Oct 6, 2018 | 05:26 PM
MURPHCC1's Avatar
MURPHCC1
dont see why not if the connection are the same.......try it out!
Old Oct 6, 2018 | 11:33 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
Make sure that you have a large enough fuse in the heated gear wiring harness.
Old Oct 7, 2018 | 03:30 AM
nobodyknowsme's Avatar
nobodyknowsme
Agree that as long as the connector is the same, no problem. I certainly hope you have a dual controller as you will need one. Also look to lightly layer the socks. I wear a very thin pair under the heated sock as well as another very thin pair on the outside. Inside to protect the sock from sweat, outside to protect the sock from wear. Just my logic and yours may/will vary.
Old Oct 7, 2018 | 10:03 AM
matthew6279
Venture heat comes with built in controller if socks are hooked to the pants.
fat_tony
General Topics/Tech Tips
Nov 19, 2017 05:21 PM
t-sport
Oct 26, 2016 08:46 PM
128auto
Oct 21, 2015 10:33 AM
jjnoble
Jan 11, 2013 12:19 AM
Funnygirl
Nov 23, 2008 07:43 PM
