Help, Please: Oil Leak.
Old Dec 15, 2018 | 08:06 AM
dkleiner's Avatar
dkleiner
The oil and filter were not recently changed..
HOWEVER: the clutch recall service was just done. The plot thickens!
Old Dec 15, 2018 | 09:17 AM
Cogswell's Avatar
Cogswell
Lucky you, sounds like a warranty repair. Take it back to the dealer with your pictures.
Old Dec 15, 2018 | 07:09 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If it's under warranty take it to the shop let them look at it, a RO will be opened and now its on file. You could also degrease the engine (super clean) take for a ride to get the motor good and hot, park over a piece of carboard then see where the oil dripped from. Another good scientific way is oil dye and a black light.
Old Dec 15, 2018 | 09:18 PM
dkleiner's Avatar
dkleiner
Is there anything about the clutch recall repair that would cause this minor leak?
Old Dec 15, 2018 | 09:35 PM
hardheaded's Avatar
hardheaded
Make sure the filter is tight ! Then give it a good washing before riding again paying special attention to that area. Then take it from there.
Old Dec 16, 2018 | 06:55 PM
Ragtop's Avatar
Ragtop
After a thorough cleaning, it helps to blow some baby power in the area of the leak.
That will help show exactly where it's coming from.
Old Dec 16, 2018 | 09:03 PM
dkleiner's Avatar
dkleiner
Has anyone else had the clutch repair? Did you lose a bit if oil?
Old Dec 17, 2018 | 12:05 PM
tar_snake's Avatar
tar_snake
Don't tighten the oil filter more than hand tight or you'll play hell ever getting the damned thing off! Hand tight is all the oil filter ever needs when putting one on.
Old Dec 17, 2018 | 12:38 PM
barneyboy's Avatar
barneyboy
The clutch (derby) cover is removed during the recall procedure, but it doesn't appear your leak is originating from that area.
Old Dec 17, 2018 | 01:09 PM
Jackie Paper's Avatar
Jackie Paper
Harleys rarely actually drip these days. Could be from a oil change trapped up there. Hard to keep a little stray on a filter change. Then it blows back . Especially down clutch cable and gets it a protective sheath if you have a cable. It should dry up. If not, it's leaking. A drip is a leak. A damp spot is not.
