2007 dyna wide glide
Old Apr 14, 2019 | 11:14 PM
Bryan Workman's Avatar
Bryan Workman
Stage II
Default 2007 dyna wide glide
Repaced battery today bike started immediately normal ride to gas station and went to restart after putting gas in the bike and heard a clicking noise and now no power at all
Checked battery and its show as a full brand new lithium battery
Just absolutely no power to the motorcycle
Any suggestions as to what the problem may be and what I can do to fix the problem
Old Apr 14, 2019 | 11:33 PM
Prot's Avatar
Prot
Your connections are loose.
Old Apr 14, 2019 | 11:40 PM
Bryan Workman
Stage II
No connections on the new battery where tight... when I replaced the new battery bike started right up first time I shut it off and turned it back on and pressed the start button it tried to start and then nothing no power at all like no battery is hooked up
Thanks
Old Apr 15, 2019 | 12:00 AM
Prot's Avatar
Prot
Check both ends of the cables as well as the cables themselves.
Something similar happened in my 95 Softail one time and it was the ignition switch.
Old Apr 15, 2019 | 12:01 AM
martinj's Avatar
martinj
Your cables can be physically tight and still not be making an electrical connection. I would check them again, and clean them well while you're at it.
Old Apr 15, 2019 | 12:24 PM
nevil's Avatar
nevil
Ground cable connection?
snarkymark
Mar 2, 2018 08:51 PM
jahwarrior007
Electrical/Lighting/Alarm
Sep 6, 2017 11:12 PM
CJSIT1461
Oct 21, 2013 07:17 PM
RandyMan
Aug 26, 2012 10:09 PM
nationalpastime
Nov 23, 2011 07:41 AM
