Tip sensor
Old May 9, 2019 | 10:03 PM
Brandi Rewis's Avatar
Brandi Rewis
Stage I
Default Tip sensor
I laid my 2018 breakout down hitting a deer now it wont crank i have no power
to my console is there any reset or tip sensors i laid it down on left side
Old May 9, 2019 | 10:17 PM
Brewmany's Avatar
Brewmany
Bike that new, I'd file a claim on my comprehensive coverage. You should have a mechanic check it out.
Old May 9, 2019 | 10:21 PM
SFinley70's Avatar
SFinley70
1. Set motorcycle upright
2. Keyed ignition:
Cycle ignition switch to OFF then IGNITION
3. Keyless ignition:
Cycle OFF/RUN switch to OFF then RUN
4. Push hazard switch to turn four way flashers off
Old May 10, 2019 | 07:53 AM
purpledeuce's Avatar
purpledeuce
Hitting a dear and laying your bike down could definitely cause some unseen problems. As was said above, file a claim and have it looked over thoroughly. Sounds like some wires may have broken
Old May 10, 2019 | 10:19 AM
nobodyknowsme's Avatar
nobodyknowsme
2. Keyed ignition:
https://youtu.be/NsUgQu9UVmA
Posts like this are what makes a forum so great.
Old May 10, 2019 | 11:45 AM
RHPAW's Avatar
RHPAW
Tip sensor? Back in my day, we called it a carburetor.
If it got sideways, the bike would stop running.
Old May 10, 2019 | 12:08 PM
Crimson's Avatar
Crimson
I wouldn't tip the deer. If anything the deer should be paying you.
Old May 10, 2019 | 02:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
We dropped the '13 Road Glide Ultra in traffic just after making a slow stop sign turn and the driver in front stopped quick and my Dyna reflex kicked in and I grabbed front brake. Went over to the bars in slo-mo. the wife and I righted it and we didn't have to reset nothing. Bike started up and got into the first available parking spot. Had lunch to flush the adrenaline. I guess the newer bikes have this feature?
Old May 10, 2019 | 06:13 PM
roadmutt's Avatar
roadmutt
The '13s have it, DAMHIK.
Old May 10, 2019 | 07:17 PM
hdbob2006's Avatar
hdbob2006
Dropped my '06 Ultra last year. Uprighted and turned ignition off-on 3 times. Reset tip over switch.
