ECM code
Old May 11, 2019 | 11:14 AM
davidv1's Avatar
davidv1
4th Gear
Default ECM code
has anyone experienced a code PO 522?
Old May 11, 2019 | 11:22 AM
GalvTexGuy's Avatar
GalvTexGuy
I found these two posts about it:
Originally Posted by ntg433
It's no longer a mystery. The P0522 code is actually an auto OBD II code. This code is a "low voltage oil sensor". I have had it come on various times even after clearing and verifying that the oil level is fine. IT WILL APPEAR EVEN WITOUT TRIPPING THE RED WARING LIGHT. I'm taking my bike in to have them check it it out. It throws the code on very hot days, I imagine because the oil is very thin and there is less pressure. THIS BEGS THE QUESTION: Is this a fault in the sensor or its circuit OR is the oil pump inadequate on those days when the oil temps are high. Time will tell. I will post back.
Originally Posted by Coastal CVO
Yep, H-D replaced mine at a little over a 1000 miles.
P0522 OBD-II Trouble Code: Engine Oil Pressure Sensor/Switch Low Voltage. P0522 code means the sensor is indicating too low of an oil pressure value due to faulty sensor, low oil, or sensor circuit.Aug 17, 2016
Old May 12, 2019 | 12:28 PM
davidv1's Avatar
davidv1
4th Gear
thank you for the info
Old May 12, 2019 | 12:29 PM
davidv1's Avatar
davidv1
4th Gear
Big Dave
Apr 3, 2016 02:12 PM
justa2z
Oct 17, 2010 06:37 PM
lkman111
Jul 27, 2008 07:36 PM
cdem02
May 3, 2007 05:34 AM
BikerGent
Apr 2, 2007 07:24 PM
