HD Ride Planner
By the way I am planning on running RT 2 once we get across the bridge and then going down to the museum on I think it was 41 before heading to ND
Here are some tips.
1. I have found RP works much better with the MS Edge browser on windows. Firefox (and Waterfox) bog down.. I would never use Chrome (I use the google search engine, I won't use any other google products.)
2. The bike and RP use different routing algorithms. The bike will take shortcuts you did not intend, and that will waste your time. In the attached picture, I need to put a way-point on the main road, otherwise my bike will take me down that ridiculous side street (Seymour), which is about 15 yards shorter, but is: practically dirt, very narrow and has a stop sign at the end. When planning routes, I look for situations like this (where the bike might try to find a shortcut) and drop a way-point around it.
3. Zoom in and check that your way-points are where you want them (on the road). If, for example, you put it on the wrong side of a divided highway, or off the road, slightly closer to a small side street, your bike will take you on a detour.
4. I leave the bike in the accessory position when filling up. that way I have a map as I pull away and it avoids other issues.
5. The Starting Point should not be the actual starting point, chose a location at least 1/4 mile away. The bike actually navigates to the starting point and it gets confused if you are already there.
I have been trying to plan short trips on the Ride Planner then import and see how well it travels my chosen routes.. So far all is good but would like to hear from you that have used it and how well it worked.
I have a 2018 TriGlide .
Easy to use, easy to download etc. so I would give it all thumbs up for sure.
For most of the last decade I have been using the GRAMIN Basecamp. Other than the time it takes to learn how to use it, it has been a great program and has become the only one I use now.
The one you are using is definitely good. And if I did not have a choice and had to use the Harley one, I would be happy with that.
The only thing I would caution you on which I think you may already know, is when you use via points, you want to make sure you are on the correct side of the road. Meaning, if you click a via point on what you think is I 90 West bound and it looks perfect but accidentally actually click on I 90 east bound, that is going to screw you up a bit. I do not remember with the Harley program but definitely with the Garmin program when I am finished mapping my trip, I "run it" where this little arrowhead goes my entire route and I watch it. If that arrowhead does a 360° turn around, or something weird, then I know I accidentally clicked on the wrong side of the road.
I hope that makes sense my friend.
