The throttle is fine, i'm sure of it. I'm so used to rolling it back that it's no problem at all. I've got the **** turned all the way to the left, the throttle just doesn't snap back. Well, on a really hot day, it will roll back slowly on it's own.. [&:]
Nope, just happens when I get on it hard, or under any other such load. For an idea of what it sounds like, I thought it was the 'shells' of my gas caps vibrating against the inner part at first, but then the other day I opened the throttle up (my throttle doesn't roll back itself) then took both hands and held the gas caps, and still heard the noise...so ruled that out.
I gotta socond the predetonation, espiecialy if you been using 87[:@]. Yor ape install is probably pinching your throtle- idle cables somewere along the line. I would take the tank off, or loosen it and, check the cables again and see if that helps [sm=signs003.gif]
Removing the primary chain inspection cover and poking in their boney digit to lift up and down on the primary chain would not be THAT far out of a task to complete.
It's free, and only takes a few minutes to do. No speculation, no guessing and you accomplish a maintenance task to boot.
IF then you still get the rattle can you can move onto a difficult task of tuning a carburetor..................which for a neophyte is a much harder thing to do.
