Normal Temps
Old Jul 4, 2019 | 07:20 AM
DonnieM's Avatar
DonnieM
I rode yesterday with the heat index at about 110 degrees. It don't take long at a light for things to heat up quick. A reality in FL riding in the summertime. We should get a cold spell in say 4 months?
Old Jul 4, 2019 | 07:21 AM
Jehu's Avatar
Jehu
Piston engine aircraft have aluminum heads and CHTs (Cylinder Head Temperatures) are monitored in climb and at cruise when leaning the mixture - yes, this is done manually by the pilot, not automatically by an ECM. The general rule is that if CHTs get above 380F the pilot should do something about it - open cowl flaps, enrichen the mixture ... something.
Once flew a plane from FL to NJ that had some stuck rings and was experiencing blow-by and associated oil consumption; CHTs in climb over hot FL where flirting with 425F a couple times.
As for your bike running differently when CHTs rose, it is very likely that the ECM retards timing when sensing elevated CHTs.
Old Jul 4, 2019 | 09:13 AM
JustDave13's Avatar
JustDave13
Originally Posted by 05UltraBob
My 2013 FLHTK has gotten as hot as 350 degrees in stop and go traffic on a 90 degree plus day. I call it "Baked potato" temperature and the temp at which I begin to look for a way to start moving again, as in riding the shoulder if on a stopped highway, or right turn lane to get the hell out of there if in town.
Same here. I don't watch temps anymore but in real hot weather I'll over heat before the bike will.
Old Jul 5, 2019 | 05:20 PM
CGLTD's Avatar
CGLTD
I say not worry about it, unless you are troubleshooting something. You wouldn't have known anyways. It's like when someone first gets an ElectraGlide and all of a sudden they are worried about the voltage they are getting and at what rpm they should shift!
Old Jul 5, 2019 | 05:29 PM
MURPHCC1's Avatar
MURPHCC1
seen my temps up the 340's..........till I got a fan.....(jasons), now never gets over 250 in stop and go....
Old Jul 5, 2019 | 09:01 PM
gerald martin's Avatar
gerald martin
Default temps
are those oil temps of cylinder head temps
Old Jul 5, 2019 | 09:40 PM
OLD 96's Avatar
OLD 96
The readout from my Power Vision the highest temp on my 2007 Ultra has been 300 degrees.That was in stop and go traffic with a ambient temp of 95 degrees.
Old Jul 6, 2019 | 05:59 AM
MURPHCC1's Avatar
MURPHCC1
Cylinder head
Old Jul 6, 2019 | 12:00 PM
94 ultra's Avatar
94 ultra
my 2 cents
people scoff at the wetheads but
my limited runs cool and in traffic fans kick on and coolant never gets above 220 and ET sensor never goes above 240 in Florida heat
natedog_37
Aug 30, 2016 11:44 AM
FinalShot
Jul 22, 2015 10:49 AM
Bucket list Trike
Oct 30, 2014 12:07 PM
Brion B
Oct 8, 2012 10:06 AM
dFREDb
Jun 10, 2009 03:01 PM
