Battery
Old Aug 11, 2019 | 02:51 PM
DGDeuce's Avatar
DGDeuce
Default Battery
Ok I'm a dumbass. I left the accessories switch on for about 5 days and the 2010 FLHTK is pretty dead. The oil light comes on but that's it. The trickle charger has been on it for 4 hours and the battery shows no sign of charging. How long for it to charge or is the battery kissed?
Old Aug 11, 2019 | 03:00 PM
Bone Doc's Avatar
Bone Doc
Your battery is likely dead. Also, a battery tender, some call them trickle chargers, will take a very long time to charge a dead battery. An actual battery charger would be better. But, if you are using the trickle charger, leave it on overnight. You can have the battery load tested at any auto parts store.
Old Aug 11, 2019 | 03:16 PM
DGDeuce's Avatar
DGDeuce
Thanks. I'll give it overnight. I've had the bike 2 years and don't know how old the battery is. Might as well get a new one anyways.
Old Aug 11, 2019 | 03:28 PM
OkieBill's Avatar
OkieBill
Get it pulled and have the local auto parts guy perform a load test. Unless you have the capability to do it yourself. A load test is free and will let you know it’s status. Got a Digital Voltmeter? Detached from the tender, what’s the voltage reading?
An an actual battery charger may help if the load test is good.
Old Aug 11, 2019 | 04:12 PM
DGDeuce's Avatar
DGDeuce
Thanks for the advice.
Old Aug 11, 2019 | 04:18 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
That isn't going to work with a flat battery.
If you get something like a C-Tek 5.0 it has a mode to resurrect a flat battery.
Old Aug 11, 2019 | 05:41 PM
Cap77's Avatar
Cap77
days...
trickle chargers only throw an amp juice
.L.T.A.
Old Aug 11, 2019 | 06:02 PM
DGDeuce's Avatar
DGDeuce
Thanks. I might just go get a new battery so I know how old it is and about how many years to get another.
Old Aug 11, 2019 | 06:44 PM
Ragtop's Avatar
Ragtop
Once a battery is totally depleted, it's pretty much junk.
You will be able to charge it back up probably, but it's lost most of its ability to hold a full charge for long periods.
Old Aug 11, 2019 | 06:49 PM
MilsurpShooter's Avatar
MilsurpShooter
IIRC Battery Tenders won't actually charge a completely dead battery, if they read dead 0 on your battery they stop. You'd have to trick it to get it into charge mode, hook it up to a good battery (car or truck) wait for it to go green and go into charge mode, then swap it quick to the dead battery.
