Gas Pump Question
.. Theres alot of tanks around in here that have alot more water than 3/4 of a inch.. but I think your chances of getting water in the tank of your bike is alot less than the chances that 16 yearold girl on the phone is gonna blow through the next stoplight and runin your day
ok ive built and serviced gas stations for 14 years.. theres about 1 quart of fuel in a hose.. the soleniod valves that choose the grade of gas are in the top of the pump.. the guy that delivers gas is right about water being heavier than gas and about the pump running out 4 to 6 inches before the tanks empty... only issue is here in iowa, they dont stick for water before dropping a load ( of fuel )
!!!! But I do buy thier gas and diesel. Buy American, ride American, burn American gas. Whenever possible, of course. "Typically", there are 2 or 3 seperate tanks, depending on whether you have 2 or 3 choices. They are strictly regulated, and required to meter them seperately. Admittedly, I'm not sure "how much"remains after regulated into the pump/hose. Running 5 gallon orsmaller tanks could dilute your blend down significantly depending on that meter point. I like the idea of rotating first fillers when in groups, sounds like a plan for our next run.
Chris
Some of the station have one hose and three buttons. When I've used them I have looked closely at what comes out of the nozzle when I first start pumping. It looks green too.
My old ironhead is real particular about gas, and it hasn't complained yet at either type of pump, and it only holds about two gallons.
The state department of agriculture periodically checks the gasoline coming out of the pumps at stations here, and evidently doesn't find any serious octane deficiency at any of these pumps.
JMO.
MC
