Missing Bolt - What is it?
Old Sep 24, 2019 | 05:40 PM
Gearhead_573's Avatar
Gearhead_573
It appears in the picture that the bolt is broke off in its bore.
Old Sep 24, 2019 | 05:45 PM
RSacky's Avatar
RSacky
I think I need #3 & 7 (just the screw and spacer)
Associated with assembly #9 (Tie Link) & 21 (Strap Ground)
This helps for sure!
Old Sep 24, 2019 | 05:52 PM
Stinger1's Avatar
Stinger1
Thats actually a reverse flow Titan actuator.
When the Titan is reversed, it allows the Spragnewton to isolate the Barb Fragmentor and thus lowering the Drag coefficient by a factor of .3. Hope this helped.
In mathematics, a coefficient is a multiplicative factor in some term of a polynomial, a series, or any expression; it is usually a number, but may be any expression.
Old Sep 24, 2019 | 05:54 PM
RSacky's Avatar
RSacky
You pointed me in the right direction first - I just couldn't wrap my little brain around it. Kudos, and thanks!
Old Sep 24, 2019 | 07:47 PM
RANGER73's Avatar
RANGER73
Who cares? Just fix it.
Old Sep 25, 2019 | 04:18 AM
Mxdad's Avatar
Mxdad
It may be just the pic but I thought the same as you, looks like the bolt is snapped off down in the threads
Old Sep 25, 2019 | 07:32 AM
bagga's Avatar
bagga
to me it looks like there are no threads left in the hole. it looks like they're stripped out.
Old Sep 25, 2019 | 08:19 AM
rigidthumper's Avatar
rigidthumper
You need a 4180 (screw) and a 6152 (spacer). This is the lower engine mount tie rod.
Old Sep 25, 2019 | 08:31 AM
upflying's Avatar
upflying
Reminds me of the Chrysler Encabulator video.
This is copy and paste material for sure.
Such double talk is often used by politicians.
Old Sep 26, 2019 | 05:49 PM
donhoe's Avatar
donhoe
http://partsfinder.onlinemicrofiche....NGINE%20MOUNTS
