Exhaust welding
Old Oct 2, 2019 | 08:32 AM
RK_Classic's Avatar
RK_Classic
Originally Posted by Mchad
Dealer doesn’t have the ability to weld Stainless
Perhaps ask your dealer who they send there welding jobs out too.
rk classic.
Old Oct 2, 2019 | 08:34 AM
RHPAW's Avatar
RHPAW
After I crashed my Shovel on my knee because of a texter, I discovered a welded mounting bracket that had broken off the exhaust pipe (the part that landed on my knee). I made a new one, but it had to be positioned perfectly to work, so I TIG welded it while on the bike. I was careful to cover the surrounding area with wet rags. I also worried about frying some electrics, but nothing came of it, and it has been good for 4 years now. Stronger that it was before, and covered by heat shields. There was no damage anywhere else on the bike.
If you have the option, I would recommend taking the pipes off though.
Old Oct 2, 2019 | 08:38 AM
bagga's Avatar
bagga
are the pipes stainless?
Old Oct 2, 2019 | 08:44 AM
Shane T's Avatar
Shane T
Any professional welder worth his salt can weld SS and better than most technicians at a dealership.
Uncle Larry's Avatar
Uncle Larry
Stainless boys ... remember he's questioning getting stainless welded
Old Oct 2, 2019 | 08:55 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by rizzo
Being it's a Harley, wouldn't be safer to have it done at the dealer instead of some exhaust shop ?
Pretty sure this site needs a sarcasm button...
I would want to talk with the "custom exhaust shop" before letting them do it...because many exhaust shops doing stainless exhaust are still mig welding it, as apposed to tig which is superior...especially in the looks dept...
A few minutes on the phone should find you a local tig welder...don't hesitate to call machine shops...most have a tig welder on staff...
Old Oct 2, 2019 | 09:30 AM
TwiZted Biker's Avatar
TwiZted Biker
Really need to ween some of you guys off that dealer titty , most can't do anything that isn't a parts swap or read to them from a trouble code.
You can tig stainless to regular steel as long as it isn't a load bearing item , I use stainless rod for 90 percent of my tig work
Old Oct 2, 2019 | 01:09 PM
dickey's Avatar
dickey
I always worry about the "Y" on my bike...a couple years ago, I bought a complete my year take-off RK exhaust from Craig's for fitty bux, just to get the "Y" pipe. What can make the "Y" crack?...mine used to get red hot before the cam & race tune.
Old Oct 2, 2019 | 01:41 PM
RK_Classic's Avatar
RK_Classic
The support bracket that attaches to the Y pipe broke and caused the crack on mine. its a 5 dollar simple bracket.
rk classic.
Old Oct 2, 2019 | 02:23 PM
0maha's Avatar
0maha
That was my take, also.
Honestly, if we're just talking welding a stainless steel sensor bung into a stainless pipe, there's nothing particularly "exhaust" or "Harley" or anything else special about it.
Good welder will give you a nice, clean result. If he's particularly conscientious, he'll back-purge the pipe so the inside stays clean and there's less flow interference.
