Wheel Bearings
I've seen that video before. The guy pops the wrong side off, the outside of the seal sits in a groove in the outer race and you have to dig into that, risking nicking or tearing the seal. Slide a small thin flat screwdriver under the inside, where it just rides against the inner race, and it's a lot easier. I've done hundreds of bearings this way and never damaged one. Rubber/plastic seals of course, metal shielded, you'll wreck it every time.
Well see how long these last.
I lost a rear at 23k miles, 150 mi from home, replaced with a timken brand, says made in USA. seems like a small bearing for such a heavy bike. was not a lot of grease so packed them with wheel bearing grease. sprocket side was toast, brake side not bad but also am running my belt a bit on the loose side now.
None of them are perfect, I've read that Goldwings have had wheel bearing failures, too. I do all my own work, so without labor costs, and having the tools for it, it's not a big deal for me to replace wheel bearings; if I did buy a new Harley for the first time, I'd pull the wheels and check the bearings just like I've done on my used bikes - and so far all of those with ball bearings, Harleys, Hondas and a Yamaha, needed new bearings, but I think they were all do to being pressure washed and getting grit in the bearings. Do the proper maintenance, at least check the wheel bearings every tire change (I'd do that on any bike) and most Harleys last a long time without problems; we're hearing about a very small percentage of them on the forum.
I checked mine back in February when I mounted up new tires and they were fine then. maybe I'll check them again before cold weather arrives...
Had a rear one go out on my 2017 dyna. Was on the freeway at the time, felt like I was riding in a bad rut. Got off the freeway, kept hearing a loud tink every now and then. Turned out I was shooting ball bearings into my license plate (on side). Thankfully I was only a dozen miles from a dealer and still under warranty. It destroyed the wheel hub and brake rotor. Would have been a $1000 problem.
Only sign I can think of was I heard a loud chirp every now and again. I thought it was the alarm on my bike since it sounded like that shortening out.
Still the best thing I ever bought.
A failure like you describe is potentially life threatening and unacceptable IMO. Motorcycling is already dangerous enough without the manufacturer sabotaging us with cheap, under designed parts.
