Another charger question
Old Nov 23, 2019 | 12:20 PM
Down South's Avatar
Down South
Battery Tender Jr is what I use on two bikes, boat, jet ski, jeep, lawn mower, tractor & ATV. Never lost a battery yet.
Another live thread about battery tenders
Old Nov 23, 2019 | 12:32 PM
TriGeezer's Avatar
TriGeezer
Battery Tender brand...that is all. Hook it up, and forget it. Do not use a conventional charger, or trickle charger.
Old Nov 23, 2019 | 05:04 PM
SPRINGER's Avatar
SPRINGER
Originally Posted by Hoginedgewood
I want to put a trickle charger on a timer, tried it once, the battery didn't survive the winter. Battery was brand new. So I'm wondering if what ever style charger you have, has continuity on the low voltage side when it is disconnected. I was charging half hour a day.
No offense but if you want to make it easy on yourself, don't over think it, just put on a battery tender and let it do it's job, simple and easy, that's the way I do it and no worries.
Old Nov 23, 2019 | 05:29 PM
Duracell's Avatar
Duracell
Originally Posted by Spartanden
I have battery tender on mine....for the winter...while in storage. You could pull your battery, put on a piece of wood (keep it off concrete and metal) and store in your basement. About a month before you plan to get the bike out, put your trickle charger on for a day....take it off....put it back on for a day....a couple cycles should bring the battery back to where it should be. You don't say what your bike is, but newer models will have some drain due to electronics/alarms/etc... that will put a constant drain on things. You have options....but I would not over think this too much. Really the simplest is to get the battery tender.
You can set the battery anywhere you want and on any surface. The old " it'll discharge on concrete" tale doesn't apply to today's batteries. That was from back when early batteries were built in wooden boxes.
Old Nov 23, 2019 | 06:12 PM
Down South's Avatar
Down South
You are correct.....
Old Nov 23, 2019 | 06:14 PM
Dynamick's Avatar
Dynamick
When someone named "Duracell" talks batteries, you'd be wise to listen
Old Nov 23, 2019 | 06:18 PM
Hoginedgewood's Avatar
Hoginedgewood
i like overthinking things.
Old Nov 23, 2019 | 06:29 PM
P51Driver's Avatar
P51Driver
Originally Posted by Dynamick
Truth - the H-D branded one is the knockoff, not the other way round.....
Deltran Battey Tender makes the chargers for Harley.
Old Nov 23, 2019 | 06:39 PM
Uncle Larry's Avatar
Uncle Larry
Did anyone recommend a Battery Tender ?? ;>)
Old Nov 23, 2019 | 07:04 PM
barneyboy's Avatar
barneyboy
Many of us are guilty of the same. If I may ask, what are you trying to accomplish by using a timer? After all, it failed you in the past. Seems like a lesson was learned.
