Trailers
IF you could build a structure that could stand up to the wind...it would have just as much wind drag as the V-nose trailer...
My v-nose dropped my truck to 8 mpg whether overloaded or empty...
My V-nose has a 40 sq. ft. frontal area, 180 sq. ft. of sidewall area, and 80 sq. ft. of top area...and my mpg experience is very similar to yours, which is why I am looking at an alternative for the 2400 mile trip.
My design for the cover has only 20 sq. ft. of frontal area (90% tucked behind the profile of the tow vehicle), 80 sq. ft. of sidewall area, and only 32 sq. ft. of top area. The frame will be 1.25" schedule 40 pipe with glued joints & secured to the trailer deck with metal pipe straps at ten points around the perimeter. The fitted cover will be made of 13 oz. heavy duty waterproof, tear resistant vinyl, secured to the frame base on the front and sides, with a waterproof vent flap to relieve pressure differences which will also serve as an inspection flap to check straps at every stop.
I fail to see how an enclosure with half the frontal area, less than half the sidewall area, and just over a third of the top area will have as much drag as the trailer...then there's the difference in weight, which also affects the mpg.
I am not looking to get into a contest with anyone, just trying to keep the bike free of road grime and do it as economically and efficiently as possible...if we have any aero engineers on the forum who could run the numbers I'd really like to see them. Feel free to PM me for details.
I'm in a great mood! You know what they say...Professionals built the Titanic, an amateur built the Ark!
While I don't believe it is impossible to build the structure you are planning...since you have an enclosed trailer, it just seems silly...
I highly doubt the gas savings will pay for your experiment...
The exposed side will only be two feet off the center line of my lane, so it's not like two vehicles passing with only 12-18" between them. I've driven large box trucks, motorhomes and towed travel trailers. I'm familiar with the pushing and pulling that the air between two larger vehicles experience when approaching and passing each other. Again, we're talking about things on a much, much smaller scale.
I have rented U HAUL's motorcycle trailer and can recommend it.
I currently have a 20' PJ, tandem axle landscape trailer that I have set-up with E-Z tracks to comfortably haul either 4 H-D's or 2 Tri-Glides.
I added a slanted "gravel/wind deflector" to the front using marine plywood to help protect the bikes.
It does the job and it is much easier (and cheaper) to pull than an enclosed trailer but I miss the added security and the protection for the cargo that an enclosed trailer provides.
I'm currently "on the fence", trying to decide between another enclosed trailer (that I could also use as storage for my mower) and then also use it to haul the "toys" when needed.
