O-ring
Old Mar 12, 2020 | 04:02 PM
dawg's Avatar
dawg
Originally Posted by arkiedeluxe
I have an 05 softail deluxe
Your primary doesn't use the same o-ring as the oil and tranny. It uses one of the little brown 11324 o-rings.
Old Mar 12, 2020 | 04:57 PM
carlgrover's Avatar
carlgrover
double check the cost of o rings from amazon with mcmaster carr. You may get more for your money with mcmaster carr.
carl
Old Mar 12, 2020 | 05:17 PM
arkiedeluxe's Avatar
arkiedeluxe
Default Oring
Thank you for the info.
Old Mar 12, 2020 | 05:18 PM
arkiedeluxe
Default Oring
Thanks everyone for all the replies
Old Mar 12, 2020 | 05:36 PM
Zerk's Avatar
Zerk
I wouldn't thank him if its wrong. I don't have softail, so maybe I am wrong, And I don't have your year. But on my 07 FLH the all 3 orings are the same. if I have been using the wrong one, it hasn't been an issue.
Old Mar 12, 2020 | 06:26 PM
user 47363638's Avatar
user 47363638
I think I’ve changed two o-rings in 23 years and one was last week, it finally broke.
Old Mar 12, 2020 | 07:48 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Wasn't there a model/year where the primary drain was horizontal just below the derby cover?
dawg's Avatar
dawg
07 FLH would use all three 11105 o-rings, 05 softails used the little brown 11324 jobbies on the primary drain plug.
Old Mar 12, 2020 | 07:52 PM
dawg's Avatar
dawg
Yes, there were horizontal ones that were tapered and there were horizontal ones that used the little brown o-ring. 04 started with the o-ring, whereas 03 had tapered but both horizontal. I’m sure there were other years using the horizontal as well.
Old Mar 12, 2020 | 09:39 PM
Zerk's Avatar
Zerk
I didn't know that. I always guessed they converted when they went to 6 speed in 06 and 07.
