Tire Pressure warning light
Old Jul 22, 2007 | 04:05 PM
mentor70's Avatar
mentor70
Default RE: Tire Pressure warning light
I work at a Toyota dealer, and Toyota uses two kinds of systems, One is called indirect, uses wheel speed sensors, the other is direct system, which uses presure transducers in the valve stem.
the indirect system can sense the difference in wheel speeds with lower tire presures.
the other is battery powered and sends freqency signs to the tire ECU and it translates the signal into a presures.
the Police bike which have ABS from the factory could easly have a indirect tire presure monitor added in the system.
Old Jul 22, 2007 | 04:28 PM
Cruiser 1970's Avatar
Cruiser 1970
My GMC Yukon has the sensor in the valve stem. But I'll be damned if I know how it works.
Old Jul 22, 2007 | 05:07 PM
Tommy Meisel's Avatar
Tommy Meisel
Dancemax:
A tire with lower air pressure will have a smaller rolling radius since the tire will deflect more which puts the axle on that tire closer to the road. This smaller rolling radius makes the tire turn more in the same distance as a fully inflated tire. That is how the tire speed sensors can detect a low air tire.
Old Jul 22, 2007 | 05:10 PM
UltraDuke's Avatar
UltraDuke
whats next? a light that tells me my air filter is clogged.
Old Jul 23, 2007 | 12:35 AM
pococj's Avatar
pococj
ORIGINAL: Duke3838
LOL, how about a light that says it's time to bleed the one-eyed dragon?
No offense to anyone intended, but if I wanted a car I'd buy a car. My muttersickle is "back-to-the-basics" for me.
Yeah, basics are different for everyone.
Old Jul 23, 2007 | 01:03 AM
vegashd's Avatar
vegashd
ORIGINAL: Duke3838
My cummins has a flow meter on the intake to tell you if you need the air filter changed
Old Jul 23, 2007 | 05:11 AM
77Tulsa's Avatar
77Tulsa
A low tire will rotate more than a properly serviced tirebecause its circumference is smaller than a properly serviced tire. My impalastire pressure light is triggered by a wheel speed sensorWhen I was driving Friday night dirt track cars we used tire pressure to accomplish a lot too include tire roll out.
ORIGINAL: Dancemax
I dont undesrtand this rotation speed. A lower pressure tire will rotate the same speed or just as many turns in a given distance as the high pressure tire. So there is a sensor in the valve stem?. Why not in a motor cycle. I think that willbe a great safety item.
Old Jul 23, 2007 | 05:15 AM
77Tulsa's Avatar
77Tulsa
That is incredible. Does it give you the beer temp to that is in the ice chest on top of the spare?
ORIGINAL: Navychief
ORIGINAL: 77Tulsa
Are you sure about the sensor being in the valve stem. I doubt the sensor is rotating part. Your ABS system is able to detect a tire that is making more revulsions than the others so it detects a low tire on my Impala that way. You would need ABS front and back and tires that are exactly the same circumference/ air pressureto incorperate a leak detect system and I still don't think it would be worth the trouble?
Has to be in the valve on my Tacoma, got the light checked all 4 tires and the light stayed. Called the service dept and the tech says "did you check the spare?" Sure enough, the spare was low, filled it and the light went away.
Old Jul 23, 2007 | 08:29 AM
michaelbarry's Avatar
michaelbarry
We don't need a damn tire pressure warning light on our motorcycles. [&o]
Old Jul 23, 2007 | 08:41 AM
DocHarley's Avatar
DocHarley
My wifes Leuxs can parallel park itself,and if you ever seen how my wifes drives this is a good thing!
