What would you do?
Old Jul 28, 2007 | 12:06 PM
  #31
pkenyon1's Avatar
pkenyon1
Default RE: What would you do?
I wouldnt go with gut feeling or the book, I would take the bike to the stealer and ask them directly..but do it in a way that you dont understand the meaning of the manual..before you tell them you have a problem; otherwise, if they know you have it they will want to take your $600
Old Jul 28, 2007 | 12:09 PM
  #32
drrandall1's Avatar
drrandall1
run it
Old Jul 28, 2007 | 12:55 PM
  #33
vegashd's Avatar
vegashd
ORIGINAL: Shrek
$600 seems high dont it? Looking thru aftermarket books the average priced belt is around $175 , that leaves $425 to switch it out . Geez I'm in the wrong business.
nope, seems right on par. A $200 belt and about 5 hours labor.
now If you htink it is so high and in the wrong business switch, undercut everyone and that means you should have business flocking to you!!!! Whenyou cannot make it let me know what happened.
Old Jul 28, 2007 | 01:08 PM
  #34
tmitchellof PG's Avatar
tmitchellof PG
I would run it the way it is.
After you check it the first few times and see it's not getting any worse, it will put your mind at ease.
I'm sure HD would definitely recommend changing it, if there was even the slightest possibility of belt failure, from a small hole, anywhere other than the edge.
Tom
Old Jul 28, 2007 | 01:30 PM
  #35
x2lee's Avatar
x2lee
I would dig the rock out of it and keep an eye in it. I have seen a lot worse still on the road.
ORIGINAL: Paniolo
[hr]
[align=left]So I got to have a new tire installed on the rear today. As the wrench is removing the rear wheel, he calls me over to look at something in my belt.
I picked up a rock that worked its way all the way through the belt. I made some calls, and it looks like I'm facing about $600.00 to change it out. That seems high, but that's what I was quoted by one dealer and one indy. [/align][/align]
http://s35.photobucket.com/albums/d1...rrent=belt.jpg
As I ride home, I tell myself that the bad news is I'll probably be out $600.00. The good news is that I found it before I hit the road later this summer.
I get home and look at the factory service manual. And if I understand their instructions correctly, the belt does NOT need to be replaced because the puncture is NOT on the edge. Does anyone else interpret this another way?
http://s35.photobucket.com/albums/d1...t=IM000002.jpg
It shows the stone coming through the belt just like mine, and it says it's okay.
What's your gut feeling?
Old Jul 28, 2007 | 02:12 PM
  #36
moondog99's Avatar
moondog99
I say run it and keep an eye on it also.
Old Jul 28, 2007 | 09:45 PM
  #37
nomad billy's Avatar
nomad billy
run it like people have said go to the dealer get the emergency belt . if u have to put the emergency belt on it set it a little looser than they tell u too,outherwise it will only go 50 miles .friend got 2500 out of his running it loose i got 65 settin it like HD said to.
Old Jul 29, 2007 | 01:10 AM
  #38
nighttraingirl's Avatar
nighttraingirl
I'd watch it and run it But I'm a girl so what do I know.
Old Jul 29, 2007 | 09:41 AM
  #39
easyglider's Avatar
easyglider
I would change it myself and save a little of the $600 AND still have the piece of mind.
saint_hog
Aug 19, 2010 04:06 AM
05FIRE
Apr 26, 2008 11:49 AM
jcboof
Mar 12, 2008 06:52 PM
starbound
Oct 2, 2006 07:46 PM
