Single Garage - Storage?
Old Sep 15, 2020 | 05:04 PM
Jehu's Avatar
Jehu
For the price of storage, an enclosed one-bike trailer might be worth looking into ... if you have a place to park it.
Old Sep 15, 2020 | 05:45 PM
brakeless's Avatar
brakeless
Having both, you can build a small shed for a lot less than a trailer with wheels and have a small work bench with enough room for a lift.
Old Sep 15, 2020 | 05:56 PM
HarleyBob52's Avatar
HarleyBob52
Originally Posted by 470004
A motorcycle doll will help to move the bike into any place in the garage.
I can't get my motorcycle doll to help me move the bike at all
Old Sep 15, 2020 | 06:54 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
The shortcoming in this method of storage is that you give a thief the means to steal both your trailer and your motorcycle at the same time!
If you choose to "store" a bike inside of a trailer, remove the tires and wheels and set the trailer on blocks and use a tongue lock and/or chain it to the ground.
Thieves will get most anything they no matter what you do to protect is but you don't want to make it too easy for them.
Old Sep 15, 2020 | 07:09 PM
Scout's Avatar
Scout
New house. With a truck, car, and a bike or two, you have at least $100,000 sitting outside. For an additional $50 grand you can protect all your assets.
I would never leave that much money sitting as a target to get stolen, or to rot in order to save $200 extra on a montage payment.
Old Sep 15, 2020 | 07:13 PM
2AMGuy's Avatar
2AMGuy
Well, sounds like you only have 6 possible directions to go:
Up over, down below, to the side, the front, or to the rear of your vehicle, or as some have mentioned, leaving your vehicle outside
If your garage is long (or deep) enough a good motorcycle swivel jack can serve as both a lift jack and a storage jack, provided that is has "locking tabs"
that will allow the pressure to be take off of he jack itself and then swiveled fla against the rear wall of the garage will enough room to also get your can inside of the garage.
If this works I'd suggest that you place a "block" on the garage floor that will let you know when you have went as far towards the rear wall as possible WITHOUT touching your bike.
EVEN with this, anything is possible when wheels and humans are operaing in close proximity.
Personally, I have car lifts along with three mezzanines where I can store two vehicles, multiple motorcycles and a trike and I still have two storage bays just to make life (and storage) easier.
If you have outdoor space, a shed or a small enclosed trailer might be an option that you want to consider but it may not be as convenient accessing your bike as it would be if you stored it in your garage and only had to move the vehicle in order to get it out.
Old Sep 15, 2020 | 07:23 PM
brakeless's Avatar
brakeless
Originally Posted by 2AMGuy
The shortcoming in this method of storage is that you give a theif the means to steal both your trailer and your motorcycle at the same time!
Theives will get most anything they no matter what you do to protect is but you don;t want to make it too easy for them.
I have a 2 bike enclosed cargo trailer but I don't park the bikes in it. It's for long trips that we want to take the bikes on. We're old and can't ride for days like we to. But I have a thick long cable I loop between the wheels of the trailer as well as one of those huge metal clamp type boots for one wheel. If someone can get past the lock on the hitch and manage to try to drive off with the trailer wheels locked and motion detectors on the bikes screaming they'd better be bullet proof cause there's 230 grain hollow points coming their way.
Old Sep 15, 2020 | 10:11 PM
ridingout's Avatar
ridingout
I'm in the park the cages in the driveway group. My street glide and the ol's road king get the garage.
Old Sep 16, 2020 | 12:01 AM
Jean-Pierre Bruwer's Avatar
Jean-Pierre Bruwer
Thanks for the advice!
Old Sep 16, 2020 | 05:07 AM
bpav16's Avatar
bpav16
I have wheeldock center stand on my road king, like the wheel chock but it stays with the bike which is convenient
