brake pads
Old Oct 4, 2020 | 02:33 PM
  #31
Bandit.'s Avatar
Bandit.
All I can say is go to the dealership and see for yourself
The oem I took off and the oem I put in both had that the chip
Old Oct 4, 2020 | 03:29 PM
  #32
Red's Avatar
Red
And there's a chip in the tire that reads the chip in your brake pad!
I'm running $8 pads on the rear of my '19 Limited. There's no chip and the ABS functions just fine. You are mistaken.
For the guys using D2Moto pads. Try discount code WS25 when you order!
Old Oct 4, 2020 | 05:11 PM
  #33
Bandit.'s Avatar
Bandit.
When I bought new ones I did a little research and discovered that oem part for rear has different part # because of ABS. The oem has a chip of some sort. The aftermarket ones don't. I don't know if it makes a difference or not. I bought the oem for the rear and aftermarket for the front. Saved about 30 bucks. All of them had the same amount of pad when I installed them. Satisfied with the results.
if you notice I said I said I don't know if it makes a difference. Glad to see it seems as though it doesn't.
Old Oct 4, 2020 | 05:59 PM
  #34
PCboiler's Avatar
PCboiler
Just ordered three sets of the Lyndall Z+...
All same part number for front and back...
Hope to get them in later in the week or weekend.
Old Oct 4, 2020 | 09:32 PM
  #35
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Very interesting? Not my experience at all.
Originally Posted by skratch
what? sorry that is not correct. there is no difference in brake pads for abs vs non abs. if there were, wouldn't the front pads have a different number too? abs works on the front as well. the difference in the part numbers is because the rear kit comes with anti squeal paste and a different pin. otherwise, the pads are exactly the same.
^^^Correct^^^
I said by my experience this is what I discovered. Go to the dealership and you will find the same thing I did. Why would the rear have a anti squeal paste and not the front if the part # isn't different?
When I was at the dealer the rear pads had a chip on them and the front didn't. How does one explain that?
Again they were different part #
Just bought and installed new pads. Brembo from dealer. The front and rear are identical. The rear does have a different part number as it comes with the template and paste. There is no chip?
the front and rear pads do indeed have a different part number, but it has nothing to do with abs. the rear has the anti-squeal paste and a different pin than the front. the pads themselves are the same, it's the extra bits that change the part number. and there is no 'chip' on the rear brakes. again, i ask, if it were for abs, why do the front not have one? abs works on the front.
^^^Correct^^^
The ABS sensors or on the bearing, not the brakes pads.
I posted pictures of the pads, the box and part numbers. Just changed them and absolutely no chips?
Old Oct 5, 2020 | 07:10 AM
  #36
Cap77's Avatar
Cap77
thanks all
got another dumb question .
got the tire replaced, how many pounds torque does the front axle get?
Googles search is showing 55 Ft lbs front, 65 rear
('04 Deuce)
any special procedure of tighten, then loosen like some vehicles?
(19K miles, I didn't replace wheel bearing/appears to be fine)
and another on torque, I may pull pull the rotor and polish it on the bench buffer (my version of "po-boy" chrome)
what torque on rotor bolts and do they get loctite?
(I have medium strength on hand)
thanks
..L.T.A.
Ruprecht
Mar 13, 2020 03:52 PM
chamokie
Oct 29, 2019 06:09 PM
TWIN CAM 96
Screamin Eagle CVO Models
Jun 15, 2011 06:47 AM
DBR7
May 2, 2011 12:07 AM
saintdaniel
Apr 10, 2008 04:11 PM
