L-Square for measuring/setting wheel alignment
Old Dec 20, 2020 | 12:44 PM
MHTR's Avatar
MHTR
Default L-Square for measuring/setting wheel alignment
I saw in another thread where one of our members made up some plugs to fit inside the rear axle. It struck me as a brilliant idea so I made up a pair. I went on a quest and found what I think is a perfect L-Square for measuring/setting wheel alignment.
FYI - It is called: Zona 37-434 L-Square, Stainless Steel, 3-Inch x 4-Inch and can be found on Amazon.
Old Dec 20, 2020 | 01:14 PM
Tozco's Avatar
Tozco
That looks good, I did that and concluded that I would be better off checking distance to the swingarm pivot so I made plugs for the pivot shaft and use a wire rod to compare right to left.
Old Dec 20, 2020 | 03:09 PM
Ruggs59's Avatar
Ruggs59
your 1/16th off
Old Dec 20, 2020 | 07:12 PM
carlgrover's Avatar
carlgrover
Yup. that's what i did too. There is a drawing in the FSM showing how to make it using a piece of music wire.
carl
Old Dec 20, 2020 | 07:57 PM
MyFavRk's Avatar
MyFavRk
Made my own alignment tool , think it was 5/16 steel rod , fit perfectly onto the pivot bolts on the swing arm .
Old Dec 20, 2020 | 08:43 PM
hellonewman's Avatar
hellonewman
Using a reference off the swingarm might be okay (maybe) but how do you know its dead on by the time you're at the front wheel? How do you do a 4 wheel alignment on a car without checking all 4 wheels?
The only way to know would be to check the alignment of both wheels the proper way then check the reference point on the arm to verify you repeat the result, then you can trust that swingarm for quick checks now and then provided the bushings never wear out. To me aligning the wheels means exactly that.
Old Dec 21, 2020 | 02:36 AM
Mart's Avatar
Mart
Agree.
Old Dec 21, 2020 | 04:01 AM
MHTR's Avatar
MHTR
Originally Posted by Ruggs59
your 1/16th off
Actually they both measure 1 and 23/32 of an inch (1.719). One side you read left to right and the other right to left.
32roadking
Touring Parts
Sep 8, 2020 02:44 PM
sagebrush1976
Touring Parts
Jul 17, 2020 03:31 PM
StGlide7
Jan 4, 2020 03:29 PM
Timbo64
Nov 19, 2018 10:16 AM
Domditizio
Apr 14, 2017 09:25 PM
