I have 2018 Fat Bob, since its winter i didn't drive for couple of months.
When i tried to start today, the vehicle makes cranky noise and doesn't start.
when i switched on the bike i see lights are on.. what could be the problem?
Battery requires a charge.
When bike is parked the bike will still have a drain due to several consumers.
The slight drain can discharge the battery over several months.
Thank you for the response.
Can you please tell me where can i find a battery charger which is inexpensive?
Amazon referenced a Deltran smart tender to keep your battery at it's peak. If your battery is really low the tender may not bring it back, but it's worth a try.In my 2013 owners manual HD recommends the use of a smart tender. Your bike should have a pigtail on the bike installed by HD and has a connector most used by small tenders. Plug your tender in at a wall outlet and the pigtail to your bike when it won't be ridden that often. Read up at Deltran at their website.
