Brake Pads
Old May 3, 2021 | 07:44 AM
Scudda's Avatar
Scudda
Default Brake Pads
Looking to change out the front Pads on my FatBoy and maybe gain a little better stopping power
In shopping around I am coming across Organic, Sintered and Carbon Fiber Pads.
I know the Organic will give the least performance out of the 3 but I am looking for opinions on which of the other 2 would be better to go with
Old May 3, 2021 | 07:57 AM
MyFavRk's Avatar
MyFavRk
I've been using EBC Double H Sintered brake pads for years , have no complaints what so ever .
Old May 3, 2021 | 09:59 AM
y22c's Avatar
y22c
DP pads.....dustless.
Old May 3, 2021 | 10:26 AM
Bobjv's Avatar
Bobjv
Brake pads
Old May 3, 2021 | 10:37 AM
WP50's Avatar
WP50
Originally Posted by Bobjv
That article saved some typing.
Good one
For myself OEM has served me well
WP
Old May 3, 2021 | 11:19 AM
Clammy's Avatar
Clammy
I use Lyndall Xtreme series pads up front on Reaper, and their Z-Plus pads in the rear. The Xtreme pads are H/H rated, and have much better stopping power, and resistance to fade, than the Z-Plus series, which are much better than stock. The X pads don't chew up rotors, and are low dusting.
Cheers!
Old May 4, 2021 | 09:28 AM
BigMike's Avatar
BigMike
Harsher brake pads, more rotor wear. Really depends on the bike and brakes. My FXR is light and has dual discs up front. Your Fatboy is heavier with a single disk. I run Drag Specialties semi metallic which is equal to stock HD and half the cost. You might want something more aggressive but they will wear faster and you'll replace the rotors eventually.
spider2
27
Nov 22, 2012 05:09 PM
proud1
Jun 10, 2010 12:14 PM
jag1886
Dec 6, 2009 08:41 AM
HATZO1
Jun 22, 2009 09:52 PM
sonar_chris
Aug 20, 2008 01:32 PM
