rear fender gap
Old Jul 24, 2021 | 05:04 AM
Kojax's Avatar
Kojax
Cool rear fender gap
i have the 2010 fatboy lo i just notice the rear fender gap . one side is wider then the other the tire does not rub everybody tells me this is normal on the softtails has anybody seen this thank you
Old Jul 24, 2021 | 05:54 AM
RANGER73's Avatar
RANGER73
Pictures,
If the wheels not centered in the fender it's a spacer issue.
As in the spacers were swapped from right to left and left to right during a tire replacement.
Or not.
Is the belt tracking true in the sprocket?
Old Jul 24, 2021 | 08:11 AM
pgreer's Avatar
pgreer
As mentioned above, check that the rear wheel is installed correctly.
But the wheels should be aligned with the swingarm and frame, not the sheet metal. The HD manual shows how to check that, and how to build a tool to measure the distance (alignment) between the axle and swingarm bold on the frams. The sheet metal can be adjusted some once everything else is aligned properly.
Paul
DynaJ
Feb 19, 2016 07:47 PM
patharley
Jan 10, 2014 06:47 PM
brettnbama
Feb 2, 2011 03:40 PM
proud1
Jul 20, 2010 02:34 PM
Raven Rider
Sep 15, 2008 05:58 PM
