Tpms
Old Aug 24, 2021 | 06:52 PM
nobodyknowsme's Avatar
nobodyknowsme
Default Tpms
Looking for good and reliable that is waterproof. Any help appreciated. Looking at FOBO?
Old Aug 24, 2021 | 08:08 PM
107inMO's Avatar
107inMO
I had fobo before I got a bike with tpms. I loved it! I installed metal t valve stems on last bike. Made it really easy to add air when needed.
Old Aug 25, 2021 | 06:06 AM
nobodyknowsme
Why metal valve stems and are they necessary?
I see the caps are approximately the size of a penny. I do have metal valve stems but the one on the rear is a 90 so I will have to see if the FOBO will fit.
Old Aug 25, 2021 | 06:11 AM
elPrez's Avatar
elPrez
YES, I have the Garmin system and didn't heed the warning. Hit 80 mph and the rear cap moved enough to strike the brake caliper, almost completely ripped the rubber stem off and 50 lbs to zero in about 10 seconds. Replaced with the metal T stem mentioned above and it's been great.
My son has the fobo and really liked them
Old Aug 25, 2021 | 06:32 AM
elPrez's Avatar
elPrez
The T stem makes topping off the air so much easier
Old Aug 25, 2021 | 07:20 PM
Ssitruc's Avatar
Ssitruc
On that 2017, IF it came with security fobs and if you have a GT6.5 or a GTS head unit, all you have to do is add the H-D valve stems/sensors with a rubber bushing if you have the 11.4mm holes in your rims so they fit tight (if you have rims with the 8.3mm hole they fit those). Then get a dealer to enable TPMS in the BCM, pair the new sensors, and enable TPMS under Radio Customazations… and you’ll have it on your stereo. Also if you know someone with Diag4Bike, it can enable it also.
just another option, guys have been doing it for a couple years now on 2014 and newer touring bikes…
https://www.hdforums.com/forum/milwa...1-tpms-16.html
if you don’t want to read all 18 pages, I went thru it and tried consolidating the information the other people figured out, and what I did..
you can start from Page 16, post 159 and see what it takes.
Old Aug 26, 2021 | 12:20 PM
nobodyknowsme
Can you steer me in the right direction for T valve stems? I have searched Google and ebay to no avail.
Old Aug 26, 2021 | 04:27 PM
Pothole914's Avatar
Pothole914
Try this:
FOBO (my-fobo.com)
Old Aug 26, 2021 | 04:28 PM
nobodyknowsme
Originally Posted by Pothole914
Thank you brother!!! I ordered the FOBO and T valve.
Old Aug 26, 2021 | 04:31 PM
Pothole914's Avatar
Pothole914
No problem.
If you decide to go the HD route let me know. I got a deal for ya.
IdahoHacker
Dec 11, 2014 10:28 PM
ffjflanagan
Apr 29, 2013 10:00 AM
desertwolf
Nov 7, 2012 10:04 AM
rwhite1
Feb 14, 2010 11:47 AM
Newman
Jan 16, 2007 11:32 PM
