Front exhaust mounting bracket
Old Aug 8, 2007 | 08:37 PM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
Default Front exhaust mounting bracket
Been hearing this rattle at low rpms that has gradually gotten worse.......inspeted the bike tonight and found that the mounting bracket for the front pipe has lost it's bolts......2 broken off and one just missing.......[:@]One of the two holes with the broken bolts is easy to get to, the other hole is blocked by the frame as well the hole missing the bolt is to blocked. I assume that they will have to pull the motor to get to these holes to machine them....
2 things........alright to ride without it??? have been basically for 1000 or more miles now, no probs.
Have a friend that can put a couple of weld on that piece of sh$t and call it a day......probs with welding???
Old Aug 8, 2007 | 09:01 PM
Kolni's Avatar
Kolni
Default RE: Front exhaust mounting bracket
I wouldn't ride it. As you ride the pipes heat up and expand, eventually you are gonna warp that end of the pipe.
You need to get get those broken bolts out to get a solid mounting point.
Old Aug 8, 2007 | 09:06 PM
HDWG's Avatar
HDWG
It is bolted to the head and then there is two bolts in the rear of the pipe as well, it does not move..like I said, that bracket has been loose and rattling quit a bit for awhile now...has not been doing much.
Old Aug 8, 2007 | 09:11 PM
Kolni's Avatar
Kolni
Can you drill them out and add a Heli-coil?
You need all thre mounting locations. Otherwise you will eventually get an exaust leak.
Old Aug 8, 2007 | 09:12 PM
Kolni's Avatar
Kolni
This is where the exaust pipes attach to the head right?
Or is it the bracket?
Old Aug 8, 2007 | 09:13 PM
HDWG's Avatar
HDWG
two of the holes you cannot get to, frame is in the way..
Old Aug 8, 2007 | 09:14 PM
Kolni's Avatar
Kolni
Well, if it is the bracket only, then you can easily have it welded. Just keep in mind that you won't be able to remove it without a heavy duty grinder.
I would just weld it.
Old Aug 8, 2007 | 09:20 PM
darkside's Avatar
darkside
Bailing wire has kept lotsa things on the road for many years now. Or just weld the ******.
Old Aug 8, 2007 | 09:23 PM
HDWG's Avatar
HDWG
I am gonna try to get with my friend this week and have him look at it, I do not think it will take a bunch of welds, just a couple to make it work.
Old Aug 8, 2007 | 09:24 PM
YUCK's Avatar
YUCK
Tack it and ride......
