Power vs Longevity
For 7K you can find a decent heritage or Road King. I picked up a Road King last year, 2006 model with hard bags for $7,000 which included shipping to my house.
It sits in my shop waiting to be turned into a drag bike when life slows down a bit. I wouldn't hesitate to ride it across country. It's a solid bike.
Having a mishap with an oil change caused a catastrophic failure around 260,000 miles and with a replacement engine the bike now has well into the 300k miles.
Then there was the recent posting of the 100,000 miles in 100 days.
I'm just under 6' and about 180, I've owned several Touring models, including Twin Cam and M8 Road Glides. I've also owned Superglides and prefer the Touring bikes for comfort on the road. As others have mentioned, once rolling you don't notice the weight. In low speeds turn around maneuvers you needs to be aware and practice until you are comfortable with it.
Paul
A bone stock Harley ridden by someone who regularly thrashes it, does burnouts, full throttle shifts, redlines a cold motor, won't last as long as a highly modified one ridden a little more conservatively most of the time.
Regular maintenance makes a difference too, oil changes, belt adjustments, etc. go a long way towards keeping it running right for many thousands of miles.
I have a little money saved for a rainy day if needed and for purposes of keeping my house payments up in the even income takes a hit. We never know what is down the road. I am also going to be coming into some money should be close to $10k, it could be couple thousand more. I’m just waiting for the judge to make a ruling. So not knowing how much or when that will be puts me into the lower end of the budget range as I have many hobbies and projects that require financial support to complete. Example ‘95 Bronco 5.8L that wants a lift, bigger tires, AC pump replaced, some body work and front/rear lockers. I think the bike would bring more smiles per miles though and be way more fuel efficient while bringing those smiles
I have been pondering all the possibilities like buying two bikes, a wrecked newer one and one with high miles and marrying the two to make a nice one with a low mile engine electronics from a newer wrecked bike. Definitely not in a hurry to get it as I have other hobbies to keep me occupied in the meantime. This is the main reason I joined to get to know as much about these bikes as I can.
2012 twin cam, is that when the 103ci was released? I have to go back and look at that wiki again for the year releases of Ci displacements?
I don’t intend to do burnouts etc, I think those days are behind me for the most part. I quit drinking lately too so that saves me some money while keeping me out of trouble “ well hopefully anyway “ and should help with improving my health so I can enjoy the bike for a few more years to come.
For now I can still do all the wrenching for adding performance enhancers but when it comes to programming a tune if it’s not plug and play then I’ll leave that to a well known good technician. At the moment I don’t know of any good techs off hand that I can trust to do good work with a good reputation.
FWIW, I retired (donated) my '00 FLTRSEI (Stage II,) to charity last year at 170,000 miles. I never split the cases. I never replaced the original clutch plates.
It could have taken me to Daytona one more time if I'd chosen to wait until March. Still strong, still dependable.
It was ready for a tear down chassis wise however and I'll let some youngster pick it up at an auction somewhere and have at it.
A Road King is considered a touring bike, because it has the same FLH frame and suspension, but it's not a full bagger.
A Softail Heritage would also make a good first bike. I've ridden all over the Country on one. Some say it isn't meant to be a touring bike, blah blah blah, but there's plenty of guys on here, myself included that have really racked up the miles on a Heritage. Plus it's a little bit lighter than a Road King, great bike for a new rider to learn on.
Here's a pic of my Heritage Softail when I toured on her....
Of course over building, using cheap parts **** poor builders can and will lead to bad results
These engine have room to grow. Done right they will be more reliable . Simple Examples any build that gets rid of HD lifters is a plus. Good aftermarket Cams are made better that stock or SE cam.
Prime example the EVO. Good reasonable cam ,maybe some head work, AC exhaust and proper tune . Rock solid many still on the road today. But when many started pushing the limits crack cases , failures..
Some engine depending on year we know they have inherent weakness . Correcting that with a build is commonsense . Examples 2019 below oil pumps there is so much information in the aftermarket on these engines just do you home work and figure out what works for you.
Always keep in mind at some point the build will effect other parts like transmission , belt , sprockets Clutch.
103 Was standard in RGU in 2011
103 was a upgrade option in others
103 Standard on all Touring bike 2012.
2007 was the standard TC96 and the end of the TC88
