jump starting harleys
Old Aug 13, 2007 | 04:57 PM
slored@fix.net's Avatar
slored@fix.net
Stage I
Default jump starting harleys
Is it ok to start late model Harleys from a 12v car or truck? If not why not, what can it hurt? Thanks, slored.
Old Aug 13, 2007 | 05:05 PM
rustyrun's Avatar
rustyrun
Default RE: jump starting harleys
Had to jump mine with a spare battery. Did no harm and that was 6 months ago.
Old Aug 13, 2007 | 05:18 PM
Sheldon's Avatar
Sheldon
my buddy had to have his bike jumped on the way to Sturgis and he did'nt have a problem with it
Old Aug 13, 2007 | 05:52 PM
SIM's Avatar
SIM
Just watch out for the airbags on the scoot.
Old Aug 13, 2007 | 06:37 PM
Sanford's Avatar
Sanford
Had to hook mine up to my truck once. Working on it and left the switch on too long. No ill effects.
Old Aug 13, 2007 | 06:43 PM
Phrogman's Avatar
Phrogman
It can be done, and sometimes that is your only choice. My only recommendation is to only jump off the battery and not with the vehicle actually running. A car/truck electrical system is still 12V, but it runs more amperage than our Harley electrics. At least going off only the battery you can limit the risk.
I should add that a lot of the "old school" wisdom is still passed down. Harleys used to run a 6V system when cars werea 12V system and back then you really could burn out the electrical system by jumping off of a car/truck.
Old Aug 14, 2007 | 08:59 AM
Flying Pilgrim's Avatar
Flying Pilgrim
I second the idea of not having the car/truck running. A buddy of mine blew out his charging system doing this. You can also push start your bike (put it in 3rd gear) get a roll, then pop clutch.
Old Aug 14, 2007 | 09:24 AM
Blackisfast's Avatar
Blackisfast
Unless of course, you have *electronic* fuel injection. The lines won't be pressurized if it's completely dead...
Old Aug 14, 2007 | 09:31 AM
kfmorris's Avatar
kfmorris
Take all the usual safety precausions etc.
Watch for grounding,,,same as usual...and it
should be just fine...I use a portable battery pac
just for a little more control over the situation....
Old Aug 14, 2007 | 09:33 AM
sleepneagle's Avatar
sleepneagle
Jumping from a cager battery is fine. Do Not have the cage running. Preferable method is to attache cage battery neg cable to a frame ground and as you start the bike, touch the cage pos cable to the bike battery pos terminal.
