2003 Road King fuel pump problem
A week later, the same thing happened again. I replaced the relay, which had checked as working, with the new one, and the bike still did not start, with the fuel pump not coming on. Had her hauled back home again! The next day she started right up without any work or checks performed.
Yesterday, I rode her around and when I got back home I shut her off in the driveway, and later I tried to move her back into the garage but she wouldn't start again! No fuel pump noise, fuel pump not working. Each time this has happened, I tried switching the ignition switch and kill switch off and on repeatedly to try and overcome the issue, but to no avail. Each time this failure to start issue has happened, it self-corrects about 8 hours later or the next morning, but it happens again later all by itself.
The problem is definitely the fuel pump intermittently does not work. Fuses and relays check out okay, and all have been replaced anyway.
I had switched off the kill switch as I usually do to cut the engine after a ride. When I tried to start her I heard a loud "ping" seeming to come from under the tank but it could have been anywhere on the right side. I just knew she wasn't going to start, and I was right. No fuel pump sound at all, and she won't start. What could this "ping" be?
Any ideas? I'm thinking the loud "ping" is important, as well as the fact that it occurred as I turned on the kill switch. Each occurrence of this problem there is apparently no voltage to the fuel pump relay. But it returns later all by itself. The problem does not seem to be the handlebar "kill" switch, but maybe yet another relay in there somewhere? Or is that a solenoid noise I heard?
It's a mind bender all right. The fuel pump just quits, then hours later it works again, then it quits again after a short ride, after an engine shut off, and an attempt to re-start. It runs for ten seconds, then the fuel pump quits again for up to 8 hours. A real and dreaded Harley-Davidson electrical gremlin.
Question: does the fuel pump get its volts from the ECM directly? Or does the ECM shut off the ground wire from the pump? Is there yet another relay between the ECM and the fuel pump? What could be killing the voltage to the fuel pump?
There are no bubbles being blown inside the fuel tank from a possible fuel line or fuel pressure regulator leak. I can either hear the fuel pump running when I turn on the ignition and she starts, or I do not hear the pump sound and she does not start. The quick disconnect/check valve under the tank works fine, no problems there. It is DEFINITELY the fuel pump not working, then later it works fine again. But why? Trying to find this intermittent trouble is very difficult, as any mechanic knows who can't duplicate the problem the customer is describing.
Perplexing. I'm like a lot of you Harley guys, who doesn't have a $$$thousand$$$ or two to drop at the stealership!
Thanks for your advice in advance!
The only other thing I might suggest is to try wiggling the ignition switch would it does not want to prime and see if there is a chance of a corrosion issue in the contacts.
Another thing to consider is - are there any safety features that may be messing you up - Kickstand switch, clutch switch? Not sure what your bike has but it's something to consider.
They're like a fuse that resets after they cool down.
. Sometimes they get weak and trip easily, but most of the time they trip due to a short to ground in your wiring.
An easy way to check is with a test light. You should have power to both poles.
I'm starting to lean toward the ECU getting an intermittent sensor reading from an electrical component, like the Crank Position Sensor, that could be causing it to disconnect the ground to the fuel pump. Can anyone confirm this is the function of the ECU in such a case?
One other question: could I possibly have a bad/failing bank sensor? I understand this shuts off power to the fuel pump if the bike tips over, to kill the motor in case of an accident. Where is this sensor located? How can I test it?
Also, I read that "too many" 100 Year Anniversary models were produced, even well into 2004, to take advantage of the demand for the Anniversary models, obviously to make more money for the Motor Company. Who who can blame them? But stories of shoddy workmanship and chinese engine bearings and other cheap parts being used in the 2003 models are all over the place, and that is not good business. "Made in the U.S.A." is the living mantra of Harley-Davidson. What a stupid thing to do, using chinese crap in their motorcycles. Makes me sad.
What say you about this? Am I experiencing the result of greed and haste and cheap parts, NOT made in the USA?!
Good luck.
No problems with the fuel hoses inside the tank, no leaks, no holes in the hoses. Mileage is very low, at 17K, not enough wear and tear to rub a hole in the tube.
I'm getting a NO-GO on the fuel pump from the ECU, I think. It's cutting off the fuel pump due to a bad crank position sensor or a bad bank angle sensor, probably.
The problem is slowly being narrowed down to one of these electrical devices, thanks to great advice from all you knowledgeable Harley riders here on Harley Davidson Forums! Thanks!
Now I need to find out the best way to test the CPS and the BAS.
Keep the suggestions coming!
