Help!!
Old Sep 19, 2022 | 04:36 PM
Spartanden's Avatar
Spartanden
OK.... couple serious thoughts here. Did you start the bike and run for about a minute? Then give it a minute or so to drain back. When you checked your oil, did you screw the dipstick back until the o'ring touches then pull back out and check? To be safe and sure, remove the transmission dipstick and check that fluid level.
Do these couple of simple checks and see if this resolves your issue. Let us know what you find.
Old Sep 19, 2022 | 04:51 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Originally Posted by Bama J
Stupid question, but is the bike on the kickstand? Must be level per service manual.
It's a trike. I don't think he needs a kickstand!
Old Sep 19, 2022 | 09:03 PM
gregintenn's Avatar
gregintenn
So what are you drinking?
Old Sep 19, 2022 | 09:35 PM
Ghost_13's Avatar
Ghost_13
Originally Posted by welltrvldman
Just changed oil in my 2021 freewheeler…put in 5 quarts… pulled oil stick.. only barely showing on stick…what happened to the oil?I have Changed oil in Harley’s hundreds of times and this has me pulling my hair out. I used the orange Harley long slender funnel… did it possibly go down in to far?where did the oil go? This is totally driving me nuts.. please help!!!
Oil went somewhere..., or you mis-measured..., or checking the wrong dip stick - figure it out
Take your gas cap off recently - just sayin
Ghost
Old Sep 19, 2022 | 09:55 PM
NorthWestern's Avatar
NorthWestern
5 comes after 4, not before.
Mystery solved.
Old Sep 20, 2022 | 06:37 AM
Camarosx2's Avatar
Camarosx2
I'd love to see a freewheeler on a kickstand
Old Sep 20, 2022 | 07:26 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I’ve been there and done that OP. Did you forget to put the drain plug back in before you poured the new oil in?
Old Sep 20, 2022 | 08:09 AM
Bama J's Avatar
Bama J
Originally Posted by FlamedFXR
Intended or not......this is a great answer.
100% intended
Old Sep 23, 2022 | 09:31 AM
welltrvldman's Avatar
welltrvldman
Stage IV
Pulled the primary cover oil poured out
Old Sep 23, 2022 | 10:18 AM
CaffeineBuzz's Avatar
CaffeineBuzz
yeah....it shouldn't do that....doesn't sound like an error on your part, you can't overfill that primary to that degree...you can overfill, just not past the bottom of the cover
