How do you get through winter?
Because of my family history with the MoCo and Milwaukee motorcycling dating back to 1912 I began in depth research into these areas about 15 years ago. I've amassed over 20,000 historic articles and photos from the very earliest years to the mid-80's. In the winter months I spend a great deal of time at my keyboard going through early mc periodicals and on sites like Ancestry and Newspapersdotcom. I didn't realize that I would become such a history junkie but I've been hooked and enjoy the discovery process a great deal.
I did NOT buy the bike just to watch it gather dust sitting in the garage for several months out of the year.
Six months ago I bought my first big Touring bike (Street Glide ST). It’s an absolute game changer for cold weather. The fairing keeps the wind off my body and hands to the point that I can go out without heated gear down to freezing and stay comfortable. The heated grips actually work because there’s not freezing air constantly drawing all the heat away from my hands. Heated vest can actually make me too hot unless I keep it turned way down.
I didn’t think I was a touring bike guy but it’s just so good at what it does, it’s an absolute beast, it’s versatile and has made cold weather riding an absolute pleasure. Well, my toes still get cold but I can deal with that!
The old wood frame divided window is falling apart
I have 2 old ones to replace, 4th window is already fixed dual pane w/another fixed dual pane as a "storm"
One has 2 broken panes & both need to be totally stripped & repainted to be used
3rd window is in better shape & has the wavy glass, so it will stay
Its the only window out of the 4 that you really see
I will take apart the 2 that are replaced, one has 2 broken panes
I will save the wavy glass & fix up the better of the 2 frames
That will be used inside the basement as an added layer of glass on the 3rd window
Delivery date is Jan 18th
Already removed the inner trim to make sure a wider 32" window will fit
No insulation in the pocket on either side
House dates back to 1910, prior owners blew insulation into the walls, it holds the heat pretty good
Not what I intended to do in the middle of Jan
But the glass is ready to fall out of 1 window
Window has not opened in a LONG time, none of them open
That is ice on the window
I cleaned & painted on both sides, knew I was going to replace the window so left that area
Are you retired?
If not what kind of work do you do that affords you the kind of mileage in a year?
You automatically grant and assign to us, and you represent and warrant that you have the right to grant and assign to us, a perpetual, irrevocable, unlimited, fully paid, fully sub-licensable (through multiple tiers), worldwide license to copy, perform, display, distribute, prepare derivative works from (including, without limitation, incorporating into other works) and otherwise use any content that you post. You also expressly grant and assign to us all rights and causes of action to prohibit and enforce against any unauthorized copying, performance, display, distribution, use or exploitation of, or creation of derivative works from, any content that you post (including but not limited to any unauthorized downloading, extraction, harvesting, collection or aggregation of content that you post).
