Why no loctite
Old Feb 10, 2023 | 05:36 PM
  #31
Madison Bill's Avatar
Madison Bill
Blue Hylamar works great and never gets hard stays soft so you can extract bolts/screws easily. Don't know about plastic... I bought a wide screen monitor and a monitor arm and I was looking for Loctite all over my house today. The bracket screws into plastic and thankfully I didn't have any from what I read.
Old Feb 10, 2023 | 05:43 PM
  #32
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by downzero
Conventional split lock washers do not work. I didn't even realize there was still anyone who thought they do. These are my first few google results:
https://www.boltscience.com/pages/he...ingwashers.htm
https://www.linkedin.com/pulse/lock-...rich-livermore
https://www.linkedin.com/pulse/nasa-...-roger-bogrash
https://www.reddit.com/r/AskEngineer...shers_useless/
I thought it was well-known, like common knowledge at this point, that lock washers are useless.
There's multiple kinds of lock washers aside from the old split spring style, keep that in mind before tossing out ultimatums like that, don't like them don't use them. And yes they do still work just fine on non high harmonic vibration applications.
You want serious retention power use these.
Old Feb 10, 2023 | 07:35 PM
  #33
Rounders's Avatar
Rounders
Originally Posted by tngarren
loctite. the worst invention besides tiktok and bitcoin. what was wrong with lock washers.
I was reading up on lock washers vs bellville. What I read was neither, thread locker. Ever see a lock washer inside an engine? I have not.
But I probably use more anti seize then I do loctite.
Old Feb 10, 2023 | 07:50 PM
  #34
Uncle Larry's Avatar
Uncle Larry
Loctite ... I put that $hit on everything ( couldn't resist )
Old Feb 10, 2023 | 07:53 PM
  #35
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Old Feb 11, 2023 | 05:07 PM
  #36
Dynamick's Avatar
Dynamick
Just don't use the red stuff on your burger or It's a trip to the ER to have your jaws pried apart
Old Feb 13, 2023 | 06:55 AM
  #37
aecs's Avatar
aecs
They get lost for one, even if you dont use the split type.
if you have locktite, and dont want to use lock washers which befome foreign objects when dropped into the insides of your motor use safety wire, the only tru way to keep a bolt in place
Old Feb 13, 2023 | 07:38 AM
  #38
hellonewman's Avatar
hellonewman
I have many times. Windage trays are an example and I have seen them directly above two mating helical gears in transaxles, those give me the ******* but I've never seen one fall off.
izzyfutch
Ironhead
Oct 20, 2022 06:54 PM
shitbox
Twin Cam Motors
Apr 20, 2022 08:02 PM
sintax
Exhaust System Topics
Aug 7, 2006 12:24 AM
