Handle Bar Position
Old Nov 16, 2005 | 06:30 PM
screwball's Avatar
screwball
Default RE: Handle Bar Position
ORIGINAL: Hooper
I have carpel tunnel syndrom that wakes me in the middle of the night hurting like crazy. I have ISO KUY grips with throttle boss. I was wondering if I adjusted my handle bars it would help. Does anyone know the rule of thumb for bar placement? I may need a riser or may need to move the bars back. Anything besides surgery to get a little relief so I can keep riding.
I always felt that the adjustment was a personal thing. I have changed the risers and position on my bike a couple of times, we have changed the bars on my wife's Nightrain twice, and she is on the 3rd set of risers. As long as you can steer make them as comfortable as you can.
Old Nov 16, 2005 | 06:44 PM
solorider's Avatar
solorider
ORIGINAL: Hooper
Solo
Please ask if you don't mind.
Will do. I should be able to have an answer by tomorrow or Friday at the latest. PM me if I forget to post.
Old Nov 16, 2005 | 08:14 PM
Wolhar's Avatar
Wolhar
Riding position is a personal thing. I can tell you this, my hands and shoulders are more comfortable with my hands slightly higher than the elbow when gripping the bars. You should be able to touch your elbow to your thigh, with feet on the pegs with a little dip in the shoulder. Aslo adjust your brake and clutch levers so the forearm and wrist are inline with fingers laying on top of the levers. This worked wonders for me. Slight adjusments in bar height make a world of difference. After making an adjustment ride the bike for several miles before deciding it isn't right.
Old Nov 16, 2005 | 09:09 PM
rrockefe's Avatar
rrockefe
Everyone is probably a little different, but usually the best position for any joint is neutral. That is not bent forward or backward at all. Especially the wrist. The shoulder could also be involved. You will have to experiment to find out what works best for you. High rise seems wrong to me as it takes the shoulder out of the normal relaxed neutral position. But, as indicated above, it has helped in some cases. You might also try a good massage therapist before you do the surgery bit. It might help...definitely won't be invasive!
Old Nov 16, 2005 | 11:11 PM
Neckball's Avatar
Neckball
distance should be no higher than.... hand position 1/2 the distance between you elbow and shoulder
I think I need more info for me to understand this............
Old Nov 16, 2005 | 11:20 PM
Snarly's Avatar
Snarly
ORIGINAL: Hooper
Hooper, My riding buddy had the same thing. He had them operated on after suffering for long time. His quote to me after he had it done was, Why the f*** didn't I do this sooner. He's a happy guy now. Just my thoughts.
Old Nov 17, 2005 | 11:48 AM
74_ironhead's Avatar
74_ironhead
i got some drag bars after three other bars and i definatly wouldn't go back they are a lot more comfortable, i'd get some drag bars with built in risers and about 2" of pulback in them but thats my opinion something else could fit you better
Old Nov 17, 2005 | 12:24 PM
palaima1's Avatar
palaima1
I"m partial to ironheads reply...drag bars work for me.
[IMG]local://upfiles/4425/DDD92A15A08F476EA394B4189B838BD6.jpg[/IMG]
[IMG]local://upfiles/4425/E5EE627640E048FC91EC988C2EFC1463.jpg[/IMG]
[IMG]local://upfiles/4425/EA32756CAC5C45828EB98BC38E952567.jpg[/IMG]
Old Nov 17, 2005 | 07:14 PM
DragonNester's Avatar
DragonNester
I also had the operation. It wasn't done before I was tested with electric shock signals through my elbow to my fingers to measure the time it took to travel the distance. On a scale of 1 to 10 I was a 7 (6 and over are considered candidates for the operation). It was quick and easy, with 100% back to normal. That was 10 years ago. DO IT AND ENJOY LIFE MORE!!
Old Nov 18, 2005 | 11:45 AM
solorider's Avatar
solorider
ORIGINAL: Hooper
Solo
Hooper,
OK, here's the scoop...and this is from the physical therapist that specializes in hand rehabilitation. Her advice for anyone suffering from carpal tunnel syndrome while riding would be to have your wrists in a "neutral" position. More specifically, without any bend up or down or right to left, with the up and down being the most crucial. As she explained, that is why you will have problems while sleeping because most of us tend to bend our wrists while we snooze. She also recommended the wrist braces for sleeping and suggested that you could try them while riding but she couldn't promise that they would help under those circumstances. Finally, she highly recommended the surgery, or at the very least seeing a physical therapist for a consultation.
Hope this helps!!
