Help identifying model
For instance, on page 6 (ignore the yellow highlighting, I was just searching):
As for becoming knowledgeable about number alterations, Palmer's discussion on pages 7 & 8 are good places to start, regardless of year:
Those pages look like they’re from the 37–64 FE and it’s one of the books I have a copy of. But those pages don’t help because they have problems and I told Palmer about them and other problems in his books via email in 2012.
For example page 6 says: ‘The first two characters are numbers, followed by two or three letter characters …’
Followed by two or three letters? What about SNs with only one letter and SNs with more than three letters? Will people think those SNs are fake because the amount of letters contradicts Palmer?
Page 6 says: ‘For the years we are dealing with …’
But does that mean 37–64 as per the front cover? Or does it mean 20–69 because page 6 has that span and it says all 20–69 H-D numbers follow the same pattern which is wrong anyway because all 20–69 H-D numbers do not follow the same pattern.
Page 8 says: ‘The numbers should be uniform. That is, fairly straight and evenly spaced.’
The truth is that some SNs, even authentic-looking ones, are not always fairly straight. And they are not always evenly spaced.
Page 8 also has a few other problems that may lead some people to think their SN is fake when in fact it may be okay.
Getting back to the number boss, page 7 says: ‘If the boss is missing …’
But the cases rocketnorton asked about are the small 1930 V-series cases so I don’t think that info will help him. Many years ago Steve Slocombe wrote an article about the two types of 1930 cases and one of the differences he pointed out was that the small left case had no number boss. And therefore I would of course expect it to be missing.
But what if someone added a number boss to the cases rocketnorton asked about? Maybe he’ll then think everything is fine because Palmer referred to a number boss. But of course it won’t be fine.
Page 7 also refers to a timing plug hole. But there was no timing plug hole on the 1930 V-series left case regardless of small case or big case.
Eric
Anyway, regarding the photo of the 34 that I posted from Hatfield’s book, are you inferring that the photo is modified and that the speedo cable was not on the R-H side for 34? If you still think the speedo cable was not on the R-H side for 34 then I’d like to see your evidence please.
Eric
And yes I realise a lot of people call all V-series machines a VL but in this instance that description won’t help the OP.
Eric
ETA: agree there is something wonky about the front fender in the OP pic - that's a '30-'33 front fender:
Not uncommon for end-of-year runs to utilize leftover stock. Or, dealer replacement of damage. All else screams '34.
@DB033
