Sorry, I've thought you were doing "traditional" breathing and removed air filter back plate.
I did now I have trans vent and since this seems not to do anything I added AC vent and yes this one works fine as I see small drop of oil on this hose already even after few hrs of riding.
Why ride it some more if you already have codes ? Battery is an easy check, however you have 22, kind of too early for battery to fail. Check terminal connections, grounds.
The reason I decided to clear codes and ride it some more is because I have so many codes that I think it was caused by weak battery in the first place as some of these are kinda major codes based on what we see so far. I did alarm siren install recently and disconnected the fuse and plug to ECM to get the module in place so I just hope this could be also part of these codes for previous no power as well as watch dog code as yes I initially I didn't disconnect things proper way so my siren went on even with fuse out as this is safety feature of the system.
Maybe riding some more wasn't smartest idea but thought I would give it a shot since I didn't have official check engine light activated.
Troubleshooting for your P2100 suggest to check your ECM connections (2nd step after turning IGN off). That's where I'd look.
Thank you for the tip I just checked it just to make sure. I run diagnostic sequence again and so far all clear but I will need to ride it so hopefully that was it.
To check your setup, you should be able to suck air through the end of that vent hose without issue. If you can't, it's somehow blocked and will never work/vent.
You should not be able to blow air into the hose because of the check valve. That's how the head breathers work.
Write the codes dowm. WTF is with this generation where everything is pictures? Why would you want to take the extra time, and why would I want to sift through a bunch of pictures?
The time it took, you could have googles.
This generation 😂 I am almost 50 years old. Write it down? Don't tell others what to do you are not my daddy. Why pictures? Because picture speaks 1000 words and is 5 times faster than write it down and more accurate? Does that work for you as explanation? And BTW you don't have to do anything related to this post if you don't want to, you can just scroll past this post and move on without pointless comment and no help anyway on the issue described. Have a good day.
WTF is with YOU, nimrod? As you're so fond of saying, if you don't like what's in the thread, change the channel.
