Replacing bulbs with LEDs
Old Jun 9, 2024 | 10:32 AM
07UltraGuy's Avatar
07UltraGuy
You can likely get LED 'bulbs' for the tank console here:
https://www.superbrightleds.com/vehi...at-light-bulbs
They've been in the LED bulb game for a long time.
Their website and product offerings have gotten more complex since my last visit though.
Old Jun 9, 2024 | 10:36 AM
RANGER73's Avatar
RANGER73
Originally Posted by Clammy
I went LED close to 20 years ago. Back then, I installed, and still have installed, the Kuryakyn "Panacea" system, which is run/turn/brake for the rear turn signals. The rear signals are red for run and braking modes, and amber for turn mode. I run a JW Speaker Adaptive LED headlight, and the front turn signals are Kuryakyn white/amber LED inserts. They are bright white for running, and go amber for signalling. They actually add quite a bit of visible light up front, making me more visible. I know Kuryakyn gets a bad rap, but this stuff has stood the test of time, and miles. That said, if I was doing the swap from new, I would look into Custom Dynamics these days, except for the headlight. IMHO, you can't beat JW Speaker for that.
Cheers!
I like the adaptive feature of the JW Speaker, I just don't like that they chose to go with the yellow tint
to try and resemble an incandescent. I contacted them about it and they said it was intentional.
Old Jun 9, 2024 | 10:44 AM
jamala00's Avatar
jamala00
Thanks... I will check that out for sure.
Old Jun 9, 2024 | 07:45 PM
FLHTPatrick's Avatar
FLHTPatrick
I swapped out the 1157’s, 1156’s and 3157 with some LEDs I found on Amazon. The ones at the part store only had side facing diodes so I found some on Amazon that had side and rear facing diodes. I do get hyper-flash on the dash indicators but the actual lights blink normal so I just don’t worry about it.
Old Jun 9, 2024 | 09:02 PM
07UltraGuy's Avatar
07UltraGuy
If it annoys you at some point, you can get a plug & play load resistor pack for about $10-$15 that works fine.
Old Jun 9, 2024 | 09:53 PM
Clammy's Avatar
Clammy
Is that something new? My headlight is bright white, no yellow tint at all.
Cheers!
Old Jun 10, 2024 | 05:26 AM
RANGER73's Avatar
RANGER73
Cheers!
No, I'm thinking it's the original, If yours is bright white they must have changed it.
My front run/turns are white amber and it doesn't look uniform.
Old Jun 10, 2024 | 08:03 AM
RHPAW's Avatar
RHPAW
I just converted my old tractor from 6V positive ground to 12V negative ground.
I need to remember to change the lights...two in front and one in the back on a three-way switch.
I may just go LED. Not an original look, but much more functional.
Old Jun 10, 2024 | 08:24 AM
GPHDXLC's Avatar
GPHDXLC
I put rear LED lights on the back of my wife 21 Freewheeler and my 20 Sport Glide. Just call Custom Dynamic. I got mine there just plug and play, a lot brighter too.
Old Jun 10, 2024 | 08:58 AM
Scudda's Avatar
Scudda
I did this on my 05 and I used this module, plug and play. I also used their run,turn, brake module that plugs into this one to turn the rear turn lights into break lights as well
https://www.biketronics.com/bt801-smart-equalizer/
