Bagger wheel alignment, bike has a lean????
Old Jul 5, 2025 | 05:12 AM
Roberto88's Avatar
Roberto88
First, check the steering head bearings if they’re too tight or uneven, it can cause a drift. Next, verify fork alignment (loosen triple clamps, compress forks, retorque). If the tank/dash looks crooked, the frame/swingarm alignment might be off measure swingarm pivot to axle on both sides.
For the rear wheel, if it’s trailing right, try adjusting the left axle cam (move it forward slightly to pull the wheel left). Small tweaks 1/8 turn at a time then test ride.
If none of that works, a laser alignment tool or dealer-level chassis check might be needed. If it’s still under warranty, push for a deeper inspection shouldn’t drift that bad stock.
Old Jul 5, 2025 | 05:22 AM
RHPAW's Avatar
RHPAW
Too much air in the left side of the tires.
Try flattening the tires, lean the bike in the other direction, and re-fill them.
Old Jul 5, 2025 | 05:58 AM
MURPHCC1's Avatar
MURPHCC1
Even in my manual for testing FALL AWAY for the front end, it states to remove the clutch cable from the fairing so as not to impart any slight push to the right due to the way the cable is routed.
It comes from the right side of the bike, across the frame to the left side at the front of the frame at approximately a 20* angle.
The flex of the cable to straighten itself puts a little pressure on the left side of the fairing towards the right.
Thereby putting the bike into a left turn configuration.
I've tried 10* on the right saddlebag, no joy.
I just don't take both hands off the bars.
Old Jul 5, 2025 | 01:28 PM
Taxgod4u's Avatar
Taxgod4u
I am going with "they all do that". I checked and my '24 bike also does it a bit and I know it's history. Still gonna cost him pizza and beer...
Old Jul 5, 2025 | 01:43 PM
FUJILICIOUS's Avatar
FUJILICIOUS
All of mine has had that subtle pull to left….if it isnt too huge or critical, I would leave it….cpl good suggestions already given….if it sems excessive, take it to dealer and have them test ride it to make sure.
either way, get that pizza and beer !
Old Jul 5, 2025 | 06:30 PM
s-glide76's Avatar
s-glide76
Instead of having a bunch of keyboard mechanics throw in their 2 cents. Take it to the dealership. Since it's been doing it since new and it's under warranty make it their problem.
Old Jul 6, 2025 | 06:19 AM
glasspilot's Avatar
glasspilot
Guys, how about the crown in the road? I think you all are overthinking this!
Old Jul 6, 2025 | 06:39 AM
CoolBreeze3646's Avatar
CoolBreeze3646
See post #1:
I rode his bike and on a flat stretch of road with no crown and it leans to the left when you let go of the bars traveling in a straight line.
Old Jul 6, 2025 | 06:40 AM
Cap77's Avatar
Cap77
Guys, how about the crown in the road? !
his pulls to left
crown will only affect "those people" that camp out cruise in the left lane
KTF
Old Jul 6, 2025 | 08:15 PM
RHPAW's Avatar
RHPAW
Pulls left? It's Zeitz's fault.
