Harley-Davidson part 29400359, also known as the Screamin' Eagle Extreme Air Cleaner filter, has the following dimensions:
Top Outer Diameter: 14 cm
Bottom Outer Diameter: 18 cm
Bottom Inner Diameter: 15 cm
External Height: 7 cm
This filter is designed to fit 2018-later Softail models and 2017-later Touring/Trike models equipped with the round High-Flow air cleaner, part number 29400357. It is described as a performance part and is also a replacement element for the Harley-Davidson Screamin' Eagle High-Flo K&N Air Filter.
