4° Rake Kit on 2014 Wide Glide — Safe at 39°
Old Aug 13, 2025 | 08:57 PM
Nazgul's Avatar
Nazgul
Default 4° Rake Kit on 2014 Wide Glide — Safe at 39°
I’m going for a chopper-inspired look on my 2014 Wide Glide, but I don’t want to fully cut and weld the frame. My plan is to run a 4° rake kit with longer forks. I’ve seen plenty of kits online, but none list my bike as a fit. After doing some digging (and calling Harley), it turns out they do fit since most Dyna models share the same main components.
My question is — if I rake it out to 39° with a kit, is it still going to be safe to ride?
Old Aug 14, 2025 | 09:20 AM
Harley_ish's Avatar
Harley_ish
Btw, the kit in your link is to convert Midglides to Wideglides
Old Aug 14, 2025 | 07:27 PM
Nazgul's Avatar
Nazgul
yes but it seems that it’ll achieve the look I’m trying to get i just want to know is it the same thing as if i were to chop it
Old Aug 14, 2025 | 07:47 PM
multihdrdr's Avatar
multihdrdr
If you're asking if adding more rake to the trees is the same thing as adding more rake to the neck, it's not.
Adding Rake to the Trees decreases "Trail" while adding to the Neck increases "Trail" although the bike can have the same total rake either way
Nazgul
Aug 15, 2025 08:24 AM
feguy1
Nov 16, 2014 09:52 AM
four40cuda
Dyna Parts
Sep 4, 2012 10:04 AM
mhenry
Dec 20, 2011 06:13 AM
bobbsterkid7
Sep 6, 2007 09:29 AM
