Cornering Traction Control - what to expect?
I’m not so sure traction control would’ve helped or not.
My thought on it is I'm not sure anything would have helped it laying down, rider aids or not if it has no traction it can't stay up. However laying it down wasn't the big issue, it was that tank slapping caused from the grip being lost and regained. It basically would have been a high side if I was going faster. Since it happened in a second there is nothing I could have done, no reaction, no training, but traction control adjusts several times in a single second and if it knew traction was lost and cut the power, then maybe I wouldn't have had such a violent regaining and loss of power over and over.
I believe it would have helped, maybe not to the extent that I didn't lay it down, but laying it down gently and laying it down violently, even at 20mph, is a big difference in recovery. I dunno, I suppose it's all a big 'maybe', but if it's possible it can help it's probably a good investment.
But after watching some videos comparing bikes with and without it, the ones without it always look like they are about to throw the rider off the front of the bike in a high side when they re-catch their grip. And I'd like to never, ever, do one of those.
Here is one for anyone in the future looking into it, off of Harleys RDRS system. Can't fix everything but the difference of the bike at 1:10 that would have high sided and the run afterwards I think is a good argument to have traction control to anyone riding in areas with gravel. (I deal with it a lot here as gravel roads connect to paved roads)
Glad to hear you were not seriously injured.
I'd have hash marked my underwear...LOL
For those curious as to the death wobble, here's a pants painting video of it in action:
This guy does a really good job in explaining a lot of motorcycle things, here's what causes a tank slapper/ death wobble
And particularly what causes the Dyna death wobble, starting at 8:22
That video also explains how a Harley engine works and why it feels and sounds different.
My 2006 had three rubber mounts. There is no upper motor mount to keep the TOP of the engine/transmission lump from twisting laterally. My 2006 went into the wobble enough that I added a frame stabilizer and it helped, but I could always sense the engine/transmission lump wanting to move.
In 2009, HD added a fourth motor mount at the top of the engine. My 2011 was a huge improvement. I could still sense movement in the seat along what is essentially the rear-axle plane, but the handlebars don't move.
All this is on pavement. In the gravel there's much more movement, but at slower speeds there's much more reaction time that allows time to maintain equilibrium. It will still wobble, but not quickly
My
Go read this thread on RDRS (https://www.hdforums.com/forum/touri...confusion.html), My entry on "testing" my 2023 RDS/Traction control system is the last one. This thread started with the question of it is "worth the money" and ended up covering a bunch of the pros and cons. My vote is, it is definitely worth the money. You only pay for it once, it adds a few $ to the payment, and it works for the life of the bike. The $64 question becomes "would I go buy a new bike just to get it, well.......
My test was on asphalt (old, smooth, & faded) but when the tires start sliding.....
I've always tiptoed through or around gravel when I see it. I would consider running the RDRS/TC in rain mode to give it better/quicker control of the rear tire & brakes.
I would be interested in finding out if the system is quick enough to react to gravel, as it's set up for wet/dry roads. I hope your local Mothership has a knowledgeable and trustworthy source for RDRS system performance.
Let us know if you find out what the limits are.
To answer your question, if your roads are fire roads then turn of TC because you arent going to be riding fast anyways. If you are on a paved road with rocks and random gravel here and there, then keep it on.
Read up on how to manage traction on a bike and get the new edition of Total Control
