Oil Coolers...
1) It may lower oil pressure because oil is traveling though another hose
2) another thing that can clog or the hose can bust and will cause you to loose oil
3) it probably won't help you much in situations like traffic jams because it requires air flow to cool the oil
Other than that I would say go for it.
1) Engineers who understand things like friction loss and laminar flow characteristics of fluids designed the oil coolers. They make the passages large enough to handle the flow volume at the given pressure to make friction loss negligible.
2) The passages in the cooler and the inside diameter of the connecting hoses are larger than the oil passages in the engine and the oil filter is there to aid in removing junk, birds, rocks and flying insects.
3) Just by virtue of the fact the oil volume is greater, the oil will take longer to heat up. The fins on the oil cooler act as a heat sink. A certain amount of heat will be dissipated by radiation. True conduction is more efficient, but the help of more oil and more surface area will keep you bike cooler longer in traffic.
HD sells oil coolers. They have not installed everything on every bike. We get to pick and choose.
Yes, I have an oil cooler on my RK. I chose to have a simple on/off valve rather than a thermostat to regulate temp. Personal choice.
Put one on your ride and enjoy the country side!
My .02
By the way, I just put it up there as things I have heard others complain about to help present both sides of the argument.
.......... and the oil filter is there to aid in removing junk, birds, rocks and flying insects.................
It works and I run 220-230 tops, but have not done stop and go of traffic jam yet but plenty of city driving. Now here in PA I rode Saturday, 35 degrees, and could not get it over 200 no matter what, stop and go, out right WOT on my favorite play bridge, nothing would take it over that 200. Now the thermostat kicks in at 190 and opens the cooler. Every day I ride here in the winter I make sure I get my bike to 200 for a 20-30 minuet period of time to cook vapor off. Usually it is longer but I set this as MY personal time frame.
They are pricey, they DO work, the have the ability to leak as any other hose on our bikes without attention, they are in a nasty location and can catch debris, but I saw a fix with the chrome cover and a screen door insert wire cut to size and it looked slick, I don't know if you gain by convection at a stop but you do gain a slight increase in oil capacity, and did I mention it was pricey?
Install a bit of a PITA but not too bad. On a run where you are packing tools get a PVC U and two pieces of hose and throw in with your tools, then if it takes a rock or a hose breaks you can either replace the hose or use the U and hoses as a bypass off the filter mount to get home.
