Oil Coolers...
Old Dec 5, 2005 | 09:27 PM
Coaster's Avatar
Coaster
Default Oil Coolers...
Who has an oil cooler and why? Does it really increase engine life?
Old Dec 5, 2005 | 10:08 PM
fxdxsteve's Avatar
fxdxsteve
Default RE: Oil Coolers...
A good cooler will lower the oil temp significantly which should increase lubrication as well as the life of the oil and the motor with the lean running twincam motors its better safe than sorry I have an original milwaukee twins cooler which is actually two coolers that mounts in front of the down tubes I also installed the jagg oil cooler adapter so the lines connect under the oil filter instead around in the back right of the motor
steve
Old Dec 5, 2005 | 10:10 PM
John TN's Avatar
John TN
A lot of people will tell you, that you don't need it. I have the super premium cooler on my RK, my thought is it's better to have and not need, than to need it and not have.
Old Dec 5, 2005 | 10:26 PM
Coaster's Avatar
Coaster
I just checked out the milwaukee twins cooler at J&P. Great price and it looks good too. Most coolers I've looked at are $150 and up. Are you happy with it? I'm seriously considering getting one.
ORIGINAL: fxdxsteve
steve
Old Dec 5, 2005 | 10:36 PM
MegaHDman's Avatar
MegaHDman
Oil coolers with a built in thermostat are a good idea. All my bikes run oil coolers. Would never think about running an air cooled motor without one installed.
Old Dec 5, 2005 | 10:40 PM
screwball's Avatar
screwball
On our past bikes, a 1200 Sportie and my Springer I put coolers on both. Both had extensive engine work and ran hot. The coolers really helped, dropped the temp 30*. If you are going to do it, be sure and get the bipass valve. You don't want the cooler working in the winter.
Old Dec 5, 2005 | 11:08 PM
Peekaboo Bob's Avatar
Peekaboo Bob
ORIGINAL: Coaster
I have one because it is so damn hot here. I use the Super Premium cooler. I don't know that it will increase the life of my motor, common sense says it should.
Old Dec 5, 2005 | 11:33 PM
Coaster's Avatar
Coaster
ORIGINAL: UltraGeezerGlide
I kind of figured it would be good to have in hot climates. And you're right, common sense says it should be good.
Screwball, thanks for the tip. A bypass valve sounds like a good idea!
Old Dec 6, 2005 | 12:03 AM
fxdxsteve's Avatar
fxdxsteve
I'm real happy with it it dropped my oil temp about 25 degrees in the heat at laughlin before my pos temp guage dipstick crapped out .guage was accurate wires shorted out instead of the thermostat I use a couple of leather ponytail covers as oil cooler covers looks cool works great and they don't take up any space in my saddlebags
Old Dec 6, 2005 | 12:08 AM
mikeisglidn's Avatar
mikeisglidn
got one on the glide, guess cause it came with it!
