Engine Sputters When Accelerating
Old Oct 15, 2007 | 08:44 PM
stevepacman's Avatar
stevepacman
Default Engine Sputters When Accelerating
Have '03 Fatboy EFI that has an issue where the engine lacks power and hesitates as if it's starving for gas when I get on it. I've ruled out bad gas, spark plugs, air cleaner, battery voltage and cables/terminals.Anyone ever experience this type of problem? Thanks in advance.
Old Oct 15, 2007 | 09:51 PM
drdiesel1's Avatar
drdiesel1
Default RE: Engine Sputters When Accelerating
Plug Wires. Fuel pump/Filter.
Old Oct 15, 2007 | 10:07 PM
biz44's Avatar
biz44
Are you getting any sort of code....or check engine light?
Old Oct 15, 2007 | 10:24 PM
Cool Breeze's Avatar
Cool Breeze
Mine did this last month while up in Maggie Valley. The tech at Ghost Town HD in Waynesville, Jason, found my intake gasket had "rolled under". It was a simple fix and while he was changing it, he also found two service bulletions for the carb which he also fixed, at a nominal cost. Bike runs great now. He said the intake gasket is a common problem, even on brand new bikes.
Old Oct 16, 2007 | 03:37 PM
stevepacman
If the plug wires could be a possibility, can the coil cause this problem? What about the fuel pump? Where is it located? Is the fuel filter in the tank?
Old Oct 16, 2007 | 05:35 PM
drdiesel1's Avatar
drdiesel1
ORIGINAL: stevepacman
Coils work or don`t work. You could have a coil or signal wire shorting to ground under the tank.The F/P is in the tank along with the filter.
Old Oct 16, 2007 | 06:04 PM
stevepacman
Thanks for the info. Now I have enough to be dangerous- wish me luck!
Old Oct 16, 2007 | 06:07 PM
mslater741's Avatar
mslater741
does it do it when the gas tank is full ? my 02 heritage was acting like that when gas level got down to a half a tank....ends up it was a small hole in gas pickup hose ,inside gas tank...found its common problem the hose is too long and rubs...
Old Oct 16, 2007 | 06:08 PM
stevepacman
One last thought...My scoot seems to "sputter" less with a full tank of gas. When I drop below 1/2 a tank, the problem appears more frequently.
Old Oct 16, 2007 | 06:15 PM
stevepacman
mslater741, is the fuel pick-up line something I can do, or should a shop replace it?
