Engine Mods
Old Oct 25, 2007 | 12:54 PM
grizzly257's Avatar
grizzly257
1st Gear
Default Engine Mods
I have a 06 Heritage and I am looking at some mods. I had the Stage1 kit installed when it was new. I would like to know if there is some other small mods that I might do from here. I am looking for more power. I have tought about having the 103 kit installed. Also would I be better to let a Harley dealer do it or an aftermarket place? The bike still as about 5 months warranty left.
Old Oct 25, 2007 | 12:56 PM
riskyfool's Avatar
riskyfool
Default RE: Engine Mods
Installing a 103 kit would not be a small mod. Not sure if you are looking for low cost power gains or just asking what can you do (reguardless of price) to gain power.
Old Oct 25, 2007 | 01:21 PM
wjl24's Avatar
wjl24
HD seems real high to do mods in my opinion. Ask around about a good local independent shop.
The best performance gain you can probably get without doing cylinder and head work is to install a cam. That takes you to "stage II".
Old Oct 25, 2007 | 01:35 PM
R1Geezrglide's Avatar
R1Geezrglide
SE 203-204 cams or equivalent with a good tuner module will take you to the next level.
Old Oct 25, 2007 | 02:51 PM
hdpearson13's Avatar
hdpearson13
do a nice 95 build i am planning 95 10 to1 cr flat tops (hoping for a 8.8-9 to 1 CCR) with head port &polish TW37B changing the engine sprocket out for a 24t evo one and inverting the tensioner to raise gearing slightly also getting work done on manifold and the cv should make alot more than hds 103 and parts should cost under 900 dollars.
nickdoni
Engine Mechanical Topics
11
May 14, 2018 12:23 PM
edgerider
Exhaust System Topics
20
Dec 18, 2015 01:18 PM
Sage Counsel
Jul 22, 2011 12:38 PM
johnkn
Sep 10, 2008 08:55 AM
howartthou
Apr 6, 2005 11:38 AM
