Fox Creek Chaps
Old Nov 9, 2007 | 04:50 PM
questor's Avatar
questor
Default Fox Creek Chaps
1st time user of chaps and based on all the recommendations of this forum about Fox Creek Leather, I purchased chaps from them.
Received them today and thirty friggin minutes laterwith the assistance of my 'boss' we gave up. Called Fox Creek and they pointed me to the following information on their webSite. Now I just need to figure out male from female zipper, this might work. [8D]
A must read for any new chaps wearer
Not to say that there is a right or a wrong way to put on your chaps. If you have a system that works, then keep on keeping on. For newbies, we put together a quick “How To” piece on putting your chaps on and included some great fitting tips.
The first main tip is: Do not worry about the chaps touching the floor during any part of this procedure. They more than likely will end up there and should if you are doing this correctly.
[ul][*]Unzip and unsnap both legs of the chaps.[*]Grab the top of the chaps between the lacing and the back of the right leg with your right hand. Make sure the inside of the right leg is facing you.[*]Use your left hand to pass the male part of the zipper between your legs from front to back passing it to your right hand and you let go of the top.[*]Grab the female part of the zipper in your left hand.[*]Move the zippers to the front of your thigh well below the thickest part of your thigh and zip the right leg. [/ul]
[ul][*]Position the zipper towards the outside rear of the leg. Do not pull the chaps up on your leg, yet.[*]Pass the belt and the left leg of the chaps straight across behind you to your left leg just above the knee.[*]Pass the female part of the zipper from front to back between the legs passing it to your left hand. [/ul]
[ul][*]Move the zippers to the front of the thigh and zip the left leg.[*]Position the zipper to the outside of the leg towards the rear. [/ul]
[ul][*]Pull the chaps up and buckle them. Squat down and stretch them out like you are trying to bust them. Get in a catcher’s position and bounce. [/ul]
The zipper is on the outside rear of the leg because that is where it is most protected from wind and rain.
A good fit in the thigh would be if you can (just) fit your hand between your thigh and the chaps leg. When your hand is in there, you should not be able to move it around or wiggle your fingers.
You would want the belt to fasten in one of the middle grommet holes. If you are in the very first or last grommet hole, try to adjust the laces to allow for maxium fit and comfort.
Just so that you know, wherever your body puts pressure on the chaps they will stretch (where there is no pressure they will not stretch). After time they will form to you and give you the lived in feel that you desire.
If the chaps are too long, you can trim them to fit. We ask that you make sure that you have a good waist and thigh fit before trimming because once you trim the chaps we cannot take them back. The seams are glued and sewn to keep the thread from unraveling and of course the leather does not fray. Remember that it i
Old Nov 9, 2007 | 06:10 PM
cwilks's Avatar
cwilks
Default RE: Fox Creek Chaps
WOW....that's funny right thar ............a tutorial on putting chaps on.....I'd thought I'd seen everthing
Old Nov 9, 2007 | 06:15 PM
SIM's Avatar
SIM
I have a completely different system....Let me get my camera......
be right back.
Old Nov 9, 2007 | 06:17 PM
shoptroll's Avatar
shoptroll
Woulda been a lot more entertaining if she wuz naked!
Old Nov 9, 2007 | 06:18 PM
Wecroft's Avatar
Wecroft
If you needed that much help putting chaps on, I wonder how thick the "How To" manual is for the bike.
P.S. My wife draws a blank sometimes and puts the buckle in the back.
Old Nov 9, 2007 | 06:33 PM
txfxstrider's Avatar
txfxstrider
Actually I have been wearing chaps for years and many times when on a mountain trip and the weather turns cold I do not stop along the road and put on my chaps because it is such a pain in the azz. I read the above info on the FCL site a couple of weeks ago and tried it and damn if it isn't much easier and less klutzy. I had been hooking the belt up and then doing the distortion dance reaching around to start the zippers at the largest part of my thighs. I once fell down on the shoulder of the road to the amusement of my riding companion. This system works for me (at least in my garage). I may not be swift but I eventually get there.
Old Nov 9, 2007 | 06:39 PM
questor's Avatar
questor
ORIGINAL: Wecroft
My Carhartt Bibs are much easier: simply step into them and pull up.. Should have stuck with them!
Old Nov 9, 2007 | 06:40 PM
bdgreen's Avatar
bdgreen
Please, PLEASE, tellme you're not from Texas.
Old Nov 9, 2007 | 06:43 PM
Bear64's Avatar
Bear64
ORIGINAL: shoptroll
Would been a lot more entertaining if she wuz naked!
yep, sure would.
ae4782tt's Avatar
ae4782tt
I would think twice if I were you b 4 trying any complex bike maintainance!
